jruffolo Posted January 12, 2017 Share #1 Posted January 12, 2017 Advertisement (gone after registration) Hello All, I've just purchased a used S006. I've finally gotten around to spending some time with the camera, and took a few test shots tonight. Thus far, most of my shots have been shooting at apertures from wide open, until f/8 or so, with the 70 Summarit. Tonight I made a series of photos with the 30 Elmarit, using smaller apertures. When reviewing photos starting from ca. f/11 to minimum aperture, I have noticed a series of streaks across the left side of the image. I put the camera into sensor cleaning mode and examined the sensor under a bright light, and found a series of three paralell streaks about 6mm or so long, two on the lower portion of the sensor, and one on the upper. I come from an R8+DMR I've been using for the last ten years, so I'm used to wiping the sensor off with a cloth or pec pad. So, with my limited experience for this type of sensor, I'm wondering if anyone here has seen something like this before? The dots in the image appear similar to those resultant of the sensor corrosion / delamination issue on the CCD based M cameras, though I have not read of any such occurrences with S cameras. Is it possible this is residue from a wet cleaning with a smaller format sensor swab/brush? My fear is that the sensor / cover glass may be scratched... I know the only way to tell for sure would be to send the camera in for inspection; I just thought that I would get some input here in the meantime. I've attached some photos below for reference. The sample photo is a crop, taken at f/22. Thanks in advance and best regards, John Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/268179-sensor-scratch-delamination-dirt/?do=findComment&comment=3184476'>More sharing options...
Advertisement Posted January 12, 2017 Posted January 12, 2017 Hi jruffolo, Take a look here Sensor Scratch / Delamination / Dirt? . I'm sure you'll find what you were looking for!
Jeff S Posted January 12, 2017 Share #2 Posted January 12, 2017 A couple of (maybe) related threads for the S2 and S006.... http://www.l-camera-forum.com/topic/239581-sensor-problems-s2/?p=2744151 http://www.l-camera-forum.com/topic/250548-s2-sensor-corrosion/ Jeff Link to post Share on other sites More sharing options...
alan.y Posted January 12, 2017 Share #3 Posted January 12, 2017 Since the streaks are parallel they may be the residue of an earlier cleaning attempt. I suggest trying to clean it with Photographic Solutions' Eclipse solution and Sensor Swaps. Then you'll know if it's corrosion, which indeed does happen on the CCD S sensors. The cover glass of my S2 cracked on all four corners. Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted January 12, 2017 Share #4 Posted January 12, 2017 Looks like a scratch from a poor cleaning attempt to me..... Gordon Link to post Share on other sites More sharing options...
albertknappmd Posted January 13, 2017 Share #5 Posted January 13, 2017 Ditto- A scratch... However use Eclipse to exclude smear.. Albert Link to post Share on other sites More sharing options...
Justalex Posted February 17, 2017 Share #6 Posted February 17, 2017 Hi John Did you find out what the problem was? Justin Link to post Share on other sites More sharing options...
