Grid and Horizon...
Donzo98
I have grid set to 3x3.... but for some reason I can't get it show up in the EVF or LCD??
Any suggestions??
Page 190 in the manual tells you how to use the display options, but it's somewhat easy to miss when you first skim the manual: The display options you've set in the menus are selected by rotating through the different displays using a short press on the Bottom Right button. The screen sequence (depending on the options you've set in the menus) is
  1. clear view — no information
  2. top and bottom bars with exposure, frames count, battery level, etc
  3. screen 2 with histogram and saturation blinkies
  4. screen 2 with focus peaking/zebras
  5. screen 2 with grid and level tools
  6. back to 1
These display options work in conjunction with focus assist magnification as well (although you lose the level tool in screen 5).
