Shanaka Posted December 17, 2016 Share #1 Â Posted December 17, 2016 Advertisement (gone after registration) Hi all, long story short, my second hand T, after 6 months use, looks to have had its SD reader corrupted or broken. Have tried multiple ways/SD cards of trying to fix this, but no luck. I keep getting SD card is locked error. Â I am happy to use internal storage, but am desperate to update to firmware 1.6 without an SD card. Is this possible? And does anyone have step by step instructions? Â Thanks in advance Link to post Share on other sites More sharing options...
Advertisement Posted December 17, 2016 Posted December 17, 2016 Hi Shanaka, Take a look here Firmware update without SD card reader. I'm sure you'll find what you were looking for!
can-photo Posted December 17, 2016 Share #2 Â Posted December 17, 2016 Hi, It should be possible If connect camera with the USB cable, it will be seen as storage. Copy the file to the internal memory ( using storage drive), then follow the same instructions should do the trick. Link to post Share on other sites More sharing options...
Shanaka Posted December 18, 2016 Author Share #3 Â Posted December 18, 2016 Brilliant - that actually worked. Thanks. The first time I tried I didn't have a full battery. Link to post Share on other sites More sharing options...
Guest VVJ Posted December 18, 2016 Share #4 Â Posted December 18, 2016 Glad to read somebody is using that internal memory!! Â Do you think you will upgrade to the TL given the doubling of the internal memory? Link to post Share on other sites More sharing options...
Shanaka Posted December 18, 2016 Author Share #5 Â Posted December 18, 2016 I think the increase in storage alone isn't worth an upgrade to a TL. I'm looking for a significant improvement to justify upgrading. Hopefully one day this will the TL2 Link to post Share on other sites More sharing options...
