Viewfinder cap - is there such a thing?
Mr Fjeld
Just looking for a practical solution to a minor but slightly annoying problem. I bring my camera on my regular walks in the local forrest which happens to be more than slightly physical due to our typical hilly terrain. Once I try to take a photo the viewfinder fogs up instantly - but that's not a huge problem compared to the sweat left in on the glass which naturally won't just evaporate. So I've tried the usual wiping procedure with the cuff of my shirt but it's just messy. So far a patch of duct tape seems to be the best solution but now it's getting colder and it will most likely not stick very well.
Have anyone come up with a better solution or even better - is it possible to find some sort of cap which will fit?
Two suggestions. I am an enthusiast of  micro-fiber cloths. I keep a small one in my pocket. It is amazing how well it takes everything off the surface.
A better solution is an eye-cup for the viewfinder which creates some pliable space for your eye (or in my case eyeglasses). It has saved my eyeglasses certain damage.
While you look for Leica solutions, consider browsing; http://www.dagcamera.com
Best of luck,
Pico
Outside fog is not a problem since you can simply wipe it with anything without much worry. But sometimes the fog is inside and you can't wipe away. I had read an article sometime ago that Leica changed VF mounting construction at some point (before digital M) and it doesn't form a tight seal. This allows moisture to condense inside. I will have to look up for the article (it had DIY instruction to create better seal).
That's not the problem when outside cold air meets close up breathing, which fogs the VF so one can't see the subject.  I've found that the anti-fogging wipes prevent this in the first place.
As far as Pico's comments, of course a micro-fibre cloth will wipe moisture away, but unlike with the wipes, the fogging will just return when the eyes/nose are against the camera.
I also don't like eyecups; instead I buy flexible eyeglass frames that allow me to get super close the the VF, allowing full frame view without problem.
Jeff
Not only does VF fog, but glasses fog when pressed against VF......not just from breath, but from warm skin against cold.  My solution couldn't be simpler....one wipe keeps fog off glasses and VF for hours on end....breathe normally.  [Works for skiers, too....kinda hard to hold one's breath or body heat down a mountain.]
Jeff
