roverover Posted November 24, 2016 Share #1 Â Posted November 24, 2016 Advertisement (gone after registration) Question. Been reading about the newer Macro Ring and 90mm Macro f/4 Elmar lens. Literature claims: Â ...The adapter is designed to be mounted between the camera and the Leica Macro-Elmar-M 90 mm f/4.Its integrated helical screw system allows a variable extension of the lens of between 18 and 30 mmand thus enables the variation of the reproduction ratio. When mounted on the adapter, the LeicaMacro-Elmar-M 90 mm f/4 can also be used in its collapsed position for exposures up to infinity. Â my Question is about using the Macro Ring with an APO-Summicron f/2 90mm Lens on a New M. Would this set-up also focus to "infinity" when mounted together? If anyone has experience using any 90mm lens with a Macro Ring this way, i'd appreciate hearing if it will focus to infinity when mounted? Â Â Link to post Share on other sites More sharing options...
Advertisement Posted November 24, 2016 Posted November 24, 2016 Hi roverover, Take a look here Question. Been reading about the newer Macro Ring and 90mm Macro Elmar. I'm sure you'll find what you were looking for!
Exodies Posted November 24, 2016 Share #2 Â Posted November 24, 2016 I use the exact equipment you are asking about. It works well for macro but doesn't focus beyond about half a meter. Link to post Share on other sites More sharing options...
Vec Posted November 24, 2016 Share #3  Posted November 24, 2016 Have setup in question. No, with everything mounted together you cannot focus infinity.  I was disappointed at first, but further research on the 90 f/4 lens + extension combo you lose rangefinder coupling. To me that's a non-starter since I rarely use the EVF and liveview on the LCD just seems awkward for me. Link to post Share on other sites More sharing options...
roverover Posted November 24, 2016 Author Share #4 Â Posted November 24, 2016 Thanks for the both replies! So, will the Elmar Macro 90 f/4 actually focus to infinity when mounted to the M ring as stated then? This is more just a curiosity about the stated functionality. I also do understand you can only focus using LV or EVF-2 with a macro ring. Link to post Share on other sites More sharing options...
luigi bertolotti Posted November 24, 2016 Share #5  Posted November 24, 2016   my Question is about using the Macro Ring with an APO-Summicron f/2 90mm Lens on a New M. Would this set-up also focus to "infinity" when mounted together? If anyone has experience using any 90mm lens with a Macro Ring this way, i'd appreciate hearing if it will focus to infinity when mounted? No, it cannot focus to infinity by definition : any "normal" lens mounted onto an extension ring cannot anymore focus to infinity : the Macro Elmar 90 is an exception because , being retractable, its backward movement compensates for  the insertion of the extension ring. Link to post Share on other sites More sharing options...
roverover Posted November 24, 2016 Author Share #6  Posted November 24, 2016 No, it cannot focus to infinity by definition : any "normal" lens mounted onto an extension ring cannot anymore focus to infinity : the Macro Elmar 90 is an exception because , being retractable, its backward movement compensates for  the insertion of the extension ring.  OK. Thank you so much for the answer about the Elmar 90 too. I couldn't understand how that would function. All Good answers! Link to post Share on other sites More sharing options...
microview Posted November 24, 2016 Share #7  Posted November 24, 2016 Advertisement (gone after registration) Have a look at Jonathan Slack's article, where he says with the adapter retracted you can focus to infinity, but of course no rangefinder focus coupling so you need live view. http://www.slack.co.uk/2014/Leica_Macro_Elmar.html Link to post Share on other sites More sharing options...
roverover Posted November 25, 2016 Author Share #8  Posted November 25, 2016 Have a look at Jonathan Slack's article, where he says with the adapter retracted you can focus to infinity, but of course no rangefinder focus coupling so you need live view. http://www.slack.co.uk/2014/Leica_Macro_Elmar.html  I'll check the link, that helps too, thank you. Link to post Share on other sites More sharing options...
graphlex Posted November 25, 2016 Share #9 Â Posted November 25, 2016 It gets to infinity on the new one, with the adapter in place, by focusing the lens in collapsed position. Link to post Share on other sites More sharing options...
Jeff S Posted November 25, 2016 Share #10 Â Posted November 25, 2016 It gets to infinity on the new one, with the adapter in place, by focusing the lens in collapsed position. Â As noted, but only using LV, as it isn't rangefinder coupled. Explained well in Jono's article. Â Jeff Link to post Share on other sites More sharing options...
