Lost Post
Hello Andreas,
I just finished writing a Post to answer someone's question about something & went to submit it to be Posted in the appropriate Thread. There was a small note at the bottom of the page which said "post saved" & the device in the top, center sparkled as it usually does when submitting a Post.
It first would not go thru & then later, when I tried again, it went off as it usually does & then disappeared. It did not go to the appropriate spot & I could not figure a way to retrieve it. The screen said something to the effect that the Post did not go thru & the section I was writing on at the bottom of the page was blank.
If this occurs again: Is it possible to get the text I was working on back? And is it still possible now?
This has happened a number of times before.
Best Regards,
Michael
Hello Andreas,
I have had the same "your post did not got thru" notice twice from (I think) this Forum since I sent my Post, just above. This has been occurring as I have been moving around in the Forum.
My computer where I am has been continually saying that my signal & its connection have been fine here thru all of this.
Best Regards,
Michael
