hjsesq Posted June 11, 2007 Share #1 Â Posted June 11, 2007 Advertisement (gone after registration) Does anyone know where I can get IR-cut filters for Voightlander lenses? Link to post Share on other sites More sharing options...
Advertisement Posted June 11, 2007 Posted June 11, 2007 Hi hjsesq, Take a look here IR-cut filters for Voightlander. I'm sure you'll find what you were looking for!
carstenw Posted June 11, 2007 Share #2 Â Posted June 11, 2007 Foto Huppert Link to post Share on other sites More sharing options...
jaapv Posted June 11, 2007 Share #3 Â Posted June 11, 2007 But... for the 15 the Leica filter is preferable. Link to post Share on other sites More sharing options...
george_b Posted June 11, 2007 Share #4 Â Posted June 11, 2007 Photographic Equipment Sales - Robert White Since they sell them their pages also describe the lenses, etc. Link to post Share on other sites More sharing options...
geoff Posted June 11, 2007 Share #5 Â Posted June 11, 2007 Harris, Â I've just rounded out my UV/IR filter needs for my collection of eight Voightlander lenses. Â I've transitioned all my previous UV/IR filters over from B+W to Leica, especially for the wider lenses. So my previous B+Ws maybe up for grabs. What part of PA are you from? Â Most all of the Voightlander lenses I have, except for the 40mm, take a 39mm thread filter, which is now very easy to obtain. Â PopFlash.Photo seems to be as good as anyone, if not better, on stocking both the B+W and Leica UV/IR filters of various sizes. If they don't have them, most likely no one does. Just got in the 43mm Leica UV/IR filter for my Nokton 40mm from them today. Â Additionally, I received the Milich LT-M8 adapters for the screw mount Voightlanders and I am investigating having the flanges notched by John Milich for the remaining M mount Voightlanders. Â Â Geoff myspace.com/geoffotos Link to post Share on other sites More sharing options...
stevme Posted June 11, 2007 Share #6 Â Posted June 11, 2007 How do you attach the IR cut filter to the CV 15 mm lens? Is there a special holder of some sort? Â Steve Link to post Share on other sites More sharing options...
geoff Posted June 11, 2007 Share #7  Posted June 11, 2007 Advertisement (gone after registration) How do you attach the IR cut filter to the CV 15 mm lens? Is there a special holder of some sort? Steve  Use a Leica UV/IR 39mm filter, 13410, and a O-Ring. Link to post Share on other sites More sharing options...
wparsonsgisnet Posted June 11, 2007 Share #8 Â Posted June 11, 2007 That must be why the o-ring doesn't fit. I got a Leica IR/UV filter 13416 and can't get the o-ring between the lens and the filter. Â Looking for 2-sided tape. Â This lens weighs **nothing**. Â BTW, the 15mm finder works well as a viewfinder, calculating that the image is inside the viewed perspective. Sort of a case of "thinking inside the box." Link to post Share on other sites More sharing options...
Cindy Flood Posted June 11, 2007 Share #9 Â Posted June 11, 2007 Bill Parsons said: Looking for 2-sided tape. I used scotch Packing tape. I cut it in strips about the width of the Leica filter and wrapped it around until I had a tight fit. It worked great and the filter is in the hood very securely. I'm not sure all that goo on 2-sided tape would be the best thing. The packing tape is kind of thick and strong. It should be easy to remove. Â Not to hijack this thread, but I was wondering what users are doing when they use this lens on their film M's? So far I have used mine on my M3 with the IR filter in, but that is not optimum. I hope that jlm is working on a more permanent solution that might allow us to take the filter on and off of this lens. Link to post Share on other sites More sharing options...
geoff Posted June 11, 2007 Share #10 Â Posted June 11, 2007 That must be why the o-ring doesn't fit. I got a Leica IR/UV filter 13416 and can't get the o-ring between the lens and the filter. Â Â Bill, Â 13416 is the part number for the silver version, 13410 for the black. Perhaps your o-ring is to thick. Â I got to pop down to my local hardware and see if they have an assortment of different o-rings I can try out in the store. That's one project. The other is confirming that I can remove the flanges off my M-mount Voightlanders, myself, at ease, and send them into John Milich for notch milling. Link to post Share on other sites More sharing options...
DaveEP Posted June 11, 2007 Share #11 Â Posted June 11, 2007 BTW, the 15mm finder works well as a viewfinder, calculating that the image is inside the viewed perspective. Sort of a case of "thinking inside the box." Â The 21mm viewfinder works a treat with the 15, but it looks to me to be the same viewfinder as the 15, but with some frame lines added Link to post Share on other sites More sharing options...
sean_reid Posted June 12, 2007 Share #12  Posted June 12, 2007 I used scotch Packing tape. I cut it in strips about the width of the Leica filter and wrapped it around until I had a tight fit. It worked great and the filter is in the hood very securely. I'm not sure all that goo on 2-sided tape would be the best thing. The packing tape is kind of thick and strong. It should be easy to remove. Not to hijack this thread, but I was wondering what users are doing when they use this lens on their film M's? So far I have used mine on my M3 with the IR filter in, but that is not optimum. I hope that jlm is working on a more permanent solution that might allow us to take the filter on and off of this lens.  Hi Cindy,  I should have the prototype for the CV 12 filter holder here soon and John may indeed make a version for the 15. We've talked about it.  Cheers,  Sean Link to post Share on other sites More sharing options...
jlm Posted June 12, 2007 Share #13 Â Posted June 12, 2007 input required: Â it would be relatively easy to make an adapter/hood to fit the 15mm similar to the one shown for the 12mm (fits on to the outside of the existing hood, would probably use a 49mm filter glass in this case and cost $150) another option is some sort of optimzed ring that clamps the 39mm filter and its ring into the existing hood. this eould be cheaper 9i still have to figure it out, so no exact price yet. Â comments? Link to post Share on other sites More sharing options...
jaapv Posted June 12, 2007 Share #14 Â Posted June 12, 2007 I would like some ring to fit the Leica 39 filter, if you could figure it out. Maybe it could be a more effective lenshood for the cropped sensor at the same time? Link to post Share on other sites More sharing options...
jlm Posted June 12, 2007 Share #15 Â Posted June 12, 2007 sounds like a good idea; anyone know the angle of view for the 15mm on the M8? could probably make a hood/adapter using the 39mm glass and slipping into the ID of the existing hood. starting to get tricky. Link to post Share on other sites More sharing options...
jaapv Posted June 12, 2007 Share #16 Â Posted June 12, 2007 sounds like a good idea; anyone know the angle of view for the 15mm on the M8?could probably make a hood/adapter using the 39mm glass and slipping into the ID of the existing hood. starting to get tricky. Â Â Diagonal 92, vertical 60, horizontal 81 (all approx) that is for a 21 on FF Link to post Share on other sites More sharing options...
sean_reid Posted June 12, 2007 Share #17 Â Posted June 12, 2007 I would like some ring to fit the Leica 39 filter, if you could figure it out. Maybe it could be a more effective lenshood for the cropped sensor at the same time? Â I was thinking the same thing and that's what I had in mind when John and I were discussing this a couple of weeks ago. The 15 is such a compact lens and it would be good to preserve that as well as improve the lens shading. I also would want to see that filter glass be as close as possible to the front lens element. Â John, Â You know we talked about this, and I'll call you today, but my thought is an adapter that slides over the outside of the current (built-in) hood but which also holds the 39 mm filter just in front of the lens element (I think there's just enough room). That would mean that the existing hood would come up into a sort of sleeve in the adapter. It might be tricky to machine but, then, what's life without challenge? Â That would be sturdy and would provide additional shading for the lens. Â Cheers, Â Sean Link to post Share on other sites More sharing options...
george_b Posted June 12, 2007 Share #18 Â Posted June 12, 2007 Sounds like a winner, just now need to make enough for the demand. Wonder how many would be interest? I know that I would - all things being equal. Link to post Share on other sites More sharing options...
jlm Posted June 12, 2007 Share #19 Â Posted June 12, 2007 I'm on it. expect somethng next week. today the first small production run of 12mm adapters are coming back from the anodizer. Link to post Share on other sites More sharing options...
george_b Posted June 12, 2007 Share #20 Â Posted June 12, 2007 I'm on it. expect somethng next week. today the first small production run of 12mm adapters are coming back from the anodizer. I could be interested in one of these for the 12mm as well. What size filter will it take and what would the best way to pay for shipment to the UK? Link to post Share on other sites More sharing options...
