krsboz Posted August 30, 2016 Share #1 Posted August 30, 2016 Advertisement (gone after registration) I updated my beloved Q to 2.0 when it dropped. I then used it a bit and all was well. It sat for maybe a week with a battery in it. I swapped a fresh battery in yesterday, turned it on - and it booted with a Leica logo screen. It then went to the set the 'date/time' screen. After doing that, it took me to the menus and I found that it had reset all of the settings that I had setup after the firmware upgrade (metering options, play screen options, etc.). Everything seems to be functioning ok, but this has / had me scratching my head. Has anyone else experienced this? Link to post Share on other sites More sharing options...
Advertisement Posted August 30, 2016 Posted August 30, 2016 Hi krsboz, Take a look here Strange / Q reset itself? . I'm sure you'll find what you were looking for!
Big T Posted August 30, 2016 Share #2 Posted August 30, 2016 Did you change the memory card at the same time? I had the same thing happen when I was messing with the photo numbering on the mem card (Just after upgrading to 2) while trying to reset the count back to my original total count number. All good now and hasn't happened since. Link to post Share on other sites More sharing options...
krsboz Posted August 31, 2016 Author Share #3 Posted August 31, 2016 Interesting. No, I didn't swap the memory card at the same time.. just a fresh battery. It was strange because it took a few seconds longer to boot up and then went to the date/time screen.. during the boot I knew something was odd because it didn't look or seem normal. Everything has been fine since.. I put it through some paces over the last couple of days.. Just weird. Link to post Share on other sites More sharing options...
Herve5 Posted August 31, 2016 Share #4 Posted August 31, 2016 Could it be that your initial battery was completely depleted, to the extent that even the camera internal capacitors (that maintain clock and settings while you are swapping batteries for instance) would have then be exhausted too, leading to a 'cold start'? If this has happened then you may check your battery for signs of ageing (e. g. lasting less than the other one, etc.) Link to post Share on other sites More sharing options...
Gatville Posted September 2, 2016 Share #5 Posted September 2, 2016 Whilst I am happy with the new features in 2.0, especially the .dng only option, I now cannot set the camera to back button focus! The zoom/lock button will still operate the 28/35/50 feature but not any of the ael or afl functions. Anyone else had this problem? Link to post Share on other sites More sharing options...
marchyman Posted September 2, 2016 Share #6 Posted September 2, 2016 Back-button focus works on my camera. I had to check after reading your post as I usually use manual focus and hadn't checked back-button since the software update. Looking at the menu the Zoom/Lock-Button setting is AFL. Link to post Share on other sites More sharing options...
Gatville Posted September 3, 2016 Share #7 Posted September 3, 2016 Advertisement (gone after registration) Back-button focus works on my camera. I had to check after reading your post as I usually use manual focus and hadn't checked back-button since the software update. Looking at the menu the Zoom/Lock-Button setting is AFL. Thanks for that marchyman. I've now performed a factory reset, which I didn't do when I updated the firmware, and everything is working as it should. I am greatly relieved because the camera was behaving oddly ( the shutter button randomly shot video instead of stills!) and it only took me 5 minutes to set it up again after the reset. Link to post Share on other sites More sharing options...
