Neko Posted August 28, 2016 Share #1  Posted August 28, 2016 Advertisement (gone after registration)  I purchased this lens new last year. I have been using it without problems for the last months. Since the beginning the focusing ring was a bit stiff, but nothing to worry about, I thought. Few days ago I noticed that the focusing ring became stiffer and sometimes it felt like grazing, scratching inside, like grinding metal to metal, definitely not normal. I moved the focusing ring several times from minimal focusing distance to infinity  and the lens went back to normal. After using the lens without problems for 3 o 4 days the same problem became noticeable again. Then I moved the focusing ring from minimal focusing distance to infinity several times and the lens was back to normal again.Since then This focusing ring roughness is intermittent and appears with different intensity.  The lens is under warranty.  Any advice would be greatly appreciated. Link to post Share on other sites More sharing options...
Advertisement Posted August 28, 2016 Posted August 28, 2016 Hi Neko, Take a look here 50 APO focus ring roughness. I'm sure you'll find what you were looking for!
Peter Kilmister Posted August 28, 2016 Share #2 Â Posted August 28, 2016 Sorry to hear of your problem. It sounds as if a bit of grit has become part of the lens assembly. Send it back under warranty for Leica to sort it out. It's too expensive to replace and I doubt that the problem will resolve itself. Link to post Share on other sites More sharing options...
Neko Posted August 28, 2016 Author Share #3  Posted August 28, 2016 Thanks Peter for your quick replay. I´m thinking about sending an e-mail to Leica Customer Service. Link to post Share on other sites More sharing options...
simey82 Posted May 24, 2017 Share #4 Â Posted May 24, 2017 Hi Neuer, Â Just curious as to what you did with you lens? Â Did you ended up sending to back to Leica for repairs and what was the outcome? Â I recently purchased a brand new Leica 50 f2 APO and after 2 month developed the same issue. Â I ended up sending this back to Leica and it's been 3 months without an update to the cause. Link to post Share on other sites More sharing options...
Pjay Posted June 6, 2017 Share #5 Â Posted June 6, 2017 My example has the opposite problem - the aperture ring is too loose and is easily bumped to another setting than intended. Crazy that such a premium product has such patchy quality control... Link to post Share on other sites More sharing options...
