Charging M8 with USB?
tjphoto
x
A USB port provides 5v at a maximum current of 500mA. Although the M8 battery has a maximum output voltage of 4.2v, the charger requires an operating voltage of more than this, typically 12v which is provided by connecting it to a car connector or the inbuilt switched mode power supply.
The battery is also charged at about 0.75A which will overload a USB port and, depending on what it's connected to, cause the port to shut down.
The latest version of my Travel Charger has a built in USB port so that I can charge a phone or an iPod from the Travel Charger, at the same time as the M8 battery is being charged.
... The battery is also charged at about 0.75A which will overload a USB port and, depending on what it's connected to, cause the port to shut down...
Mark,
Presumably when an M8's battery is nearly flat the in-rush current would be considerably higher than 0.75 Amps - owing to the battery's low internal impedance, which could damage the M8 because, afaik, USBs don't contain surge-current protection devices do they?
Pete.
I don't mind having to charge the battery out of the camera but I sure would like the option to power the camera from the usb connector.
It would be terrific to do a long studio shoot without a battery change (of fear of the sleep syndrome).
