Hi all. I have a few times experienced the following. I use my camera in Aperture priority. No problem, but occasionally I experience, the camera chose to use 1 sec. Exposure, so that the image becomes overexposed, exfic says that the camera is in manual. I have two solutions. 1. take out the battery, or 2. Select a manual time and take a picture and then back in (A). Have others had similar error?
Regards Henrik
Sent from my iPad using Tapatalk HD
Same here, I already posted about it "Q shooting blanks" it did that during a hike a month or so ago, where the camera did that too many times that day.
I rested the camera and then traveled to Cuba, there, I used the Q almost exclusively, I don't remember seeing that issue again. I'm keeping an eye on it though.
The XVarior
Seems very strange indeed...You should contact Leica about it if it continues, espeically because it is 'getting stuck' this way....
I had a glitch similar to this once or twice in the beginning, associated with a wrong ISO setting while shooting in A mode, but it has not repeated since and there
was no 'lock-up'.
Regards Henrik
The XVarior
Henrik, did you try to reset your Leica Q to factory settings already? Maybe it could be a solution...
  • 1 month later...
I have completely forgotten to return to this thread.
The problem is still there, it comes in waves. What I've discovered is that the camera switches to Manual, you see the A symbol switches to M and shutter at 1 sec. Often it changes back to (A) after a shot, other times more. The best solution is to switch to M take a photo and go back to A. (A) means, in this case, Aperture priority. When the problem is not constant, I am not crazy about having to send it to Leica. I've tryed a complete restore, I guess it is a software bug.
Henrik
This may or may not be related, but I was using the Q and everything was fine. Numerous shots in manual mode at ISO 100. I was using remote control over wifi shooting hummingbirds. The camera stopped functioning. Don't know why. Perhaps wifi interruption. Don't know. What I next saw was several images highly over exposed. It took awhile, but I realized that the ISO had been somehow changed to 12,500. I definitely did not adjust it. Somewhere in the Q a firmware bug is lurking that did this. I reset ISO back to 100 and all was fine. Frustrating. I still love the camera.
I think I found the source of the problem, it lies in the shutter wheel, when it is set to A and I pressed lightly on the wheel, it starts to weave between M and A, like there is a loose connection in the switche.
So after the summer hollyday, it have to be returned to Leica again :( I have apparently gotten A Monday model.
  • 1 year later...
No, it has apparently fixed itself, the problem lies in the shutter dial, typically when it stood in A, if you pressed the dial it jumped over to 1 sec exposure, which is right next to A, so I guess that the two are very close so there's probably come a little dust in and has fixed the problem. I hope you get solved the problem.
All the best
Henrik
  • 4 years later...
My 6 month old Q has the exact same problem. You move it to A, and sometimes it thinks that I set it on 1 sec. And touching the dial a little can help. Did you just use/massage the dial and then it helped? Or did you clean it? I still have warranty, but would miss it for 6-8 weeks while they fix it....
(Greetings from Denmark btw Henrik...😉)
  • 11 months later...
Ok, and old thread. But just to let you know. If you have this problem, it is not dust. It is the upper electronics near the shutter button, that needs to be replaced. Leica did this on my Q, under warranty. Has been working fine after this repair.
