jaapv Posted June 6, 2007 Author Share #21  Posted June 6, 2007 Advertisement (gone after registration) Hi Jaap, Nice shots! More due to the photographer than the camera i think, so compliments to you instead of the M8 being better than the Canon.  Hans  Thanks Hans Not better, but better for the job - for me. Link to post Share on other sites More sharing options...
Advertisement Posted June 6, 2007 Posted June 6, 2007 Hi jaapv, Take a look here Real men use manual - AF is for the birds.... I'm sure you'll find what you were looking for!
Artichoke Posted June 6, 2007 Share #22  Posted June 6, 2007 these photographs are an inspiration, as are your comments Dear Jaap i think you have Viso as well. Do you find the RF or screen SLR focusing easier in these situations (bird fligt) regards I picked up a 560 Telyt for a bargain price from KEH and used it for birds in flight with the Viso the Viso has a crop (which Jaap kindly gave the details in another post), so there is a greater view than the area captured, which is a great advantage for this kind of photography as Jaap pointed out manual focus is not all that difficult once you get the hang of it and I got many sharply focused shots ...unfortunately I needed to dial in more negative compensation and lost many otherwise fine captures to overexposure from my first birding outing ...white birds against the sky/foliage need a good deal of negative compensation ...sadly I was so intent on maintaining my balance & getting the shots that I did not chimp sufficiently to pick up this problem until I got home ...the M8's LCD in very bright light is not all that useful once you get the exposure down (which I didn't in my first outing) putting the Viso in the "yellow dot" mode allows for rapid shutter release with very little if any shutter lag I need to find time to get back to some birds with this combination I also need to find an ir/cut and polarizer for this lens, but that is an altogether other problem & one that may not be so easy to accomplish:mad: Link to post Share on other sites More sharing options...
gogopix Posted June 6, 2007 Share #23 Â Posted June 6, 2007 One thing I learned with Viso is the need for 'slow shutter' your exposure probelems may be due to the sensors not having enough time to sense the light (or the mirror is not quick enough in getting out of the way, an adjustment issue. Link to post Share on other sites More sharing options...
jaapv Posted June 6, 2007 Author Share #24  Posted June 6, 2007 Dear Jaap i think you have Viso as well. Do you find the RF or screen SLR focusing easier in these situations (bird fligt) regards   I don't know yet, Victor. It surely depends on the distance and size of the bird. For this situation I feel the RF focussing was better. I have the plan to take the M8s, Visoflex with Brightscreen, Noflexar 400 follow-focus, the 280 and 135 (and some short stuff) on an extended Africa trip in October. I will be in Kafue and Busanga Plains and maybe the Benguerra Swamps in Zambia for a couple of weeks then and go back to my "roots" - I took a similar set on my M3 in the late seventies to the Masai Mara in Kenia and was very pleased with the result at that time, that being my first go at real wildlife photograpy. Expect me to bore you all to tears with my posts on the subject in November and December. Link to post Share on other sites More sharing options...
HaraldL Posted June 6, 2007 Share #25 Â Posted June 6, 2007 Jaap, Â As many said before, nice shot. I'm also curious about the comments that would have followed on birdpix.nl. I think they are also interested in the green belly. Â Harald Link to post Share on other sites More sharing options...
DaveEP Posted June 6, 2007 Share #26 Â Posted June 6, 2007 try as i might, i fail to see the connection here.while i might agree on point #1 ("I could see the birds fly into the frame, he could not..."), i must disagree with point #2. Â The big problem with DSLRs is that you don't see the bird until it comes in to the frame (almost too late). This makes you late taking off with your panning movement, so it's possible that you don't pan fast enough to keep up with it. So, you end up with only part of the bird in the frame, and also effects the AF system too! Link to post Share on other sites More sharing options...
jaapv Posted June 6, 2007 Author Share #27 Â Posted June 6, 2007 Advertisement (gone after registration) And Dolphins... Summilux 75 Â Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted June 6, 2007 Share #28 Â Posted June 6, 2007 Jaap i never want to see you with a AF lens in your hands , you simply will never need one. Now that is a shot Link to post Share on other sites More sharing options...
manolo Posted June 7, 2007 Share #29  Posted June 7, 2007 does spots count? 75 /2 summicron Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/26037-real-men-use-manual-af-is-for-the-birds/?do=findComment&comment=275162'>More sharing options...
Artichoke Posted June 7, 2007 Share #30 Â Posted June 7, 2007 One thing I learned with Viso is the need for 'slow shutter' your exposure probelems may be due to the sensors not having enough time to sense the light (or the mirror is not quick enough in getting out of the way, an adjustment issue. I always do a test shot using the black dot mode in A priority & then set the speed manually using yellow dot mode to release the shutter ...with the Viso III I have found this the best way for action photography sadly I was too caught up in the thrill of capturing the birds to pay heed to my LCD ...the foliage was perfectly exposed, but the white birds blown, mostly that said, I had some that came out well & I believe I have learned from this experience, particularly as the M8 does so well with recovering shadows Link to post Share on other sites More sharing options...
HaraldL Posted June 7, 2007 Share #31 Â Posted June 7, 2007 Jaap, Â Had a nice holliday? I do remember a thread about diving and M 8 and something with dolphins...How about those pictures, new thread?? And did you really try a M8 in a plastic bag? Â Harald Link to post Share on other sites More sharing options...
jaapv Posted June 7, 2007 Author Share #32  Posted June 7, 2007 Jaap, Had a nice holliday? I do remember a thread about diving and M 8 and something with dolphins...How about those pictures, new thread?? And did you really try a M8 in a plastic bag?  Harald  As a matter of fact I didn't, Harald. I did modify my plan to taking the Digilux2 underwater however, as that seemed to be a more practical tool. Ewa Marine has an incredible backlog in production, so I was not able to get the plastic bag in time. My dealer kindly sold me a Casio EXLIM with underwater housing at cost as a replacement, and I did not even get around to downloading the SD card yet.... Link to post Share on other sites More sharing options...
jaapv Posted June 17, 2007 Author Share #33 Â Posted June 17, 2007 Been working my files - found this one... Link to post Share on other sites More sharing options...
