Need for IR filters on Monochrome M
Judy Babinski
Obviously, you will not get any purplish hues where there is a high proportion of IR light. However, parts of the subject might implausibly appear too light when lit by IR light. I would presume that it was mostly a matter of taste, but I have no way of testing that.
The MM is less IR sensitive than your M8, but it is hardly relevant. For B&W photography filtering IR light has a minimal impact.
I would advise you to use a middle yellow filter from time to time on the Monochrom, depending on the subject.
Thanks for the responses.  That is what I thought but wanted to confirm.  I know the M8 can be used for the infrared effect although I have never used it in that regard.   Didn't know if that effect could be achieved, although to a lesser degree, with the MM.
