Tae Young Lee Posted April 6, 2016 Share #1  Posted April 6, 2016 Advertisement (gone after registration) Recently, I bought a leica O replica model on ebay.  According to the review, it is told that the lens quality is better than older elmar lens.  However, I don't know how I can load the film using spool.  I can't pool the spool out from the camera.  Is there anyone who knows loading the film?  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/258993-film-loading-for-leica-o-replica/?do=findComment&comment=3021403'>More sharing options...
Advertisement Posted April 6, 2016 Posted April 6, 2016 Hi Tae Young Lee, Take a look here film loading for leica O replica. I'm sure you'll find what you were looking for!
wattsy Posted April 6, 2016 Share #2  Posted April 6, 2016 It can be tricky to get the spool out of the camera – you just need to wiggle it a bit and possibly pull it with a little more force than you might be expecting. If you are really struggling try using an elastic band or piece of string to hook the end of the spool and give you more purchase. To load the film, it is advisable to trim the film leader as per the instructions that come with the 0 camera (there are also plenty of instructions on the web about trimming the leader for LTM cameras) although there is a "business card" trick that some people use as well. Link to post Share on other sites More sharing options...
Tae Young Lee Posted April 6, 2016 Author Share #3  Posted April 6, 2016 It can be tricky to get the spool out of the camera – you just need to wiggle it a bit and possibly pull it with a little more force than you might be expecting. If you are really struggling try using an elastic band or piece of string to hook the end of the spool and give you more purchase. To load the film, it is advisable to trim the film leader as per the instructions that come with the 0 camera (there are also plenty of instructions on the web about trimming the leader for LTM cameras) although there is a "business card" trick that some people use as well. Thank you for your advice. I did it! Link to post Share on other sites More sharing options...
M9reno Posted April 6, 2016 Share #4 Â Posted April 6, 2016 Now, putting the spool back, once you have the film attached, you have to look for a notch inside the spool, that fits a matching notch on the spindle. Â Otherwise the spool won't go back in. Link to post Share on other sites More sharing options...
M9reno Posted April 6, 2016 Share #5 Â Posted April 6, 2016 Regarding the lens, have a look at the following. Â Hopefully your lens will be ok, but mine suffered from flare until it was (easily) repaired. Â http://www.l-camera-forum.com/topic/250711-anastigmat-0-series-replica-funbut-flare/ Link to post Share on other sites More sharing options...
Tae Young Lee Posted April 7, 2016 Author Share #6  Posted April 7, 2016 I have one more question. Today, I have took a photo with bw film. However, when I developed the film, I found that the half of the frame was over-exposed. When I look at the film, the half showed really good image, but the other half showed completely black color. When I took a photo, I did the close the front of the lens with the cap after the shoot a scene. Then, I turned the shutter dial and then I opened the caps and shoot. What's the problem? Link to post Share on other sites More sharing options...
earleygallery Posted April 7, 2016 Share #7 Â Posted April 7, 2016 Advertisement (gone after registration) You probably fouled the shutter dial as you took the photo, which would cause the shutter to malfunction. Link to post Share on other sites More sharing options...
M9reno Posted April 7, 2016 Share #8  Posted April 7, 2016 I have one more question. Today, I have took a photo with bw film. However, when I developed the film, I found that the half of the frame was over-exposed. When I look at the film, the half showed really good image, but the other half showed completely black color. When I took a photo, I did the close the front of the lens with the cap after the shoot a scene. Then, I turned the shutter dial and then I opened the caps and shoot. What's the problem?  The sequence of actions that you describe here does not quite match what the instructions require:  1.  Shoot a scene. 2.  Cap the lens. 3.  Wind the film to the position where the shutter dial can be turned (red dot).  Change shutter slit width at this point, if desired. 4.  Continue to cap the lens. 5.  Wind the film further to the position where the shutter can be fired.  6.  Uncap the lens.  And repeat.  If you uncap and shoot directly after turning the shutter dial, then you are not winding the shutter fully, and exposing film that is only partly wound. Link to post Share on other sites More sharing options...
jc_braconi Posted April 8, 2016 Share #9 Â Posted April 8, 2016 It seems that I have red : do not wind the film until you want to take an other picturedid I remember well ? Link to post Share on other sites More sharing options...
M9reno Posted April 8, 2016 Share #10 Â Posted April 8, 2016 It seems that I have red : do not wind the film until you want to take an other picture did I remember well ? Â Yes - exactly for the reason that you can only set the slit width ('shutter speed') half-way through the wind (step 3 in my post). Â If you wind the film, then you have no exposure control using the shutter, but using the aperture only. Â In practice this situation is fine: Â if you know the general lighting conditions, then wind, uncap, and be ready for the next shot, fine adjusting the aperture as needed. Link to post Share on other sites More sharing options...
Tae Young Lee Posted April 17, 2016 Author Share #11 Â Posted April 17, 2016 Yes - exactly for the reason that you can only set the slit width ('shutter speed') half-way through the wind (step 3 in my post). Â If you wind the film, then you have no exposure control using the shutter, but using the aperture only. Â In practice this situation is fine: Â if you know the general lighting conditions, then wind, uncap, and be ready for the next shot, fine adjusting the aperture as needed. Â 3. Â Wind the film to the position where the shutter dial can be turned (red dot). Â Change shutter slit width at this point, if desired. Â I'm sorry, I hardly understand it. Could you show me more details or photos? Link to post Share on other sites More sharing options...
FrozenInTime Posted April 17, 2016 Share #12  Posted April 17, 2016 I scanned the manual a few years ago - hope it helps:  http://www.donaldingram.com/RFF/Leica_OSeriesManual.pdf  Gratuitous shot of my 0-series in half case ( yes I cut off the front of the full case )  Link to post Share on other sites More sharing options...
M9reno Posted April 17, 2016 Share #13 Â Posted April 17, 2016 Tae Young Lee, see the pictures on p. 28 of the manual linked in the previous post, and description of what my step 3 entails on p. 29. Link to post Share on other sites More sharing options...
