spylaw4 Posted June 5, 2007 Share #21 Posted June 5, 2007 Advertisement (gone after registration) I have just posted some observations re manual focus in the D vs. R lens thread. [in case you are interested]. Link to post Share on other sites More sharing options...
Advertisement Posted June 5, 2007 Posted June 5, 2007 Hi spylaw4, Take a look here pictures of your digilux 3/l1 with manual focus lenses.. I'm sure you'll find what you were looking for!
audidudi Posted June 5, 2007 Share #22 Posted June 5, 2007 Hi Jeffery, What adapter are you using with the Voigtlander lens on your L1? I have 3 Voigtlander lenses and I'd love to use them on my L1..Where did you purchase it? Thanks in advance..Bill ~ I'm using a 4/3->Nikon adapter and my Voigtlander lenses are the (now discontinued) versions made with a Nikon F-mount. These lenses use the same glass elements as the LTM and M-bayonent versions but they're recessed further into the mount to compensate for the differences in flange-to-focal plane distances between Leica (~28.7mm) and Nikon (46mm) ... in other words, my approach only works with a select handful of Voigtlander lenses, all of which are no longer available. Link to post Share on other sites More sharing options...
S. Wong Posted June 5, 2007 Share #23 Posted June 5, 2007 has anyone put the 16mm/2.8 fisheye on the L1/Digilux 3? I wonder what that would look like (both of and through it) as I own neither, I was wondering if someone who does would mind posting some thank you -Steven Link to post Share on other sites More sharing options...
imnotaniceboy Posted June 5, 2007 Author Share #24 Posted June 5, 2007 ...and I wonder what would look like Zeiss ZF lenses on digilux3/l1. Maybe Ill buy the 50mm 1.4 to have 100mm 1.4. Of course, I will need to buy a nikon f adapter. gustavo Link to post Share on other sites More sharing options...
bgood2 Posted June 5, 2007 Share #25 Posted June 5, 2007 I'm using a 4/3->Nikon adapter and my Voigtlander lenses are the (now discontinued) versions made with a Nikon F-mount. These lenses use the same glass elements as the LTM and M-bayonent versions but they're recessed further into the mount to compensate for the differences in flange-to-focal plane distances between Leica (~28.7mm) and Nikon (46mm) ... in other words, my approach only works with a select handful of Voigtlander lenses, all of which are no longer available. * Thanks Jeffery, I thought this was too good to be true for me to use lenses I already have..appreciate the fast responce and the info..wouldn't you know I have the lenses they don't have an adapter for, thanks again..Bill ~ Link to post Share on other sites More sharing options...
rollsman4 Posted November 29, 2016 Share #26 Posted November 29, 2016 I just purchased the D3 and want to know what Options I have with Zoom Lens I can use with AF on my D3 that give Excellent IQ Thank you, Link to post Share on other sites More sharing options...
dkCambridgeshire Posted December 3, 2016 Share #27 Posted December 3, 2016 Advertisement (gone after registration) I just purchased the D3 and want to know what Options I have with Zoom Lens I can use with AF on my D3 that give Excellent IQ Thank you, There are three AF Panasonic Leica 4/3 zoom lenses (as distinct from Micro 4/3 i.e. M4/3 designs) which can be used with the D3: 1) 14-50mm f2.8-3.5 - an excellent lens and standard equipment for the D3 2) 14-50mm f3.8-5.6 - also a good lens but not as good throughout the zoom range as the faster f2.8-3.5 option - originally offered with the Panasonic L1 4/3 camera which is a D3 clone 3) 14-150mm f3.5-5.6 - a superzoom model equivalent to 28-300mm full frame - available secondhand but pricey e.g. £500 ish - and a superb lens throughout its zoom range. There is also the PanaLeica 25/1.4 AF 4/3 lens which is a highly regarded 4/3 prime lens. Additionally all the Olympus 4/3 zoom and prime lenses are usable on the D3 but they are available in three different qualities i.e. budget , mid-range and pro-range . The mid-range optics are excellent e.g. the Olympus 12-60mm 4/3 lens; the pro range 4/3 optics are still sought after and expensive. 4/3 lenses can be used on both 4/3 cameras and, via an adapter, on M4/3 cameras. But M4/3 lenses cannot be used on 4/3 format cameras - even though both use the same size sensor. There were also a few independently manufactured 4/3 lenses e.g. by Sigma and Samyang. Many legacy manual focus lenses can also be used via adapters … but only for manual focus … not AF. If you acquired your D3 with an AF zoom lens it’s likely to be the 14-50mm f2.8-3.5. Ignore any criticisms of the D3 - it’s still a capable workhorse albeit a little slow compared to modern cameras. 4/3 format still has a dedicated following by 4/3 and M4/3 enthusiasts You should consider accessing the 4/3 forums to learn more about 4/3 and Micro 4/3 cameras and lenses and which are recommended by experienced users. Ffordes Photographic is one of the few dealers still specialising in secondhand 4/3 lenses (as distinct from M4/3) - and worth a browse to see what's available. http://www.ffordes.com/category/Lenses/4/3rds Best wishes dunk Link to post Share on other sites More sharing options...
