ynp Posted March 10, 2016 Share #1 Posted March 10, 2016 Advertisement (gone after registration) Hello, I was offered a Hasselblad HC 3.5/50-II for a good price and it goes with the HC Macro Converter. Does anyone know if the Macro Converter works with the S-to-Hasselblad H adapter? Link to post Share on other sites More sharing options...
Advertisement Posted March 10, 2016 Posted March 10, 2016 Hi ynp, Take a look here Hasselblad Macro Converter with the Leica S . I'm sure you'll find what you were looking for!
jip Posted March 10, 2016 Share #2 Posted March 10, 2016 'Macro Converter' is that the actual name of the 'ring' because I don't see it listed in the manual of the Leica S-Adapter H which can be found here: https://uk.leica-camera.com/content/download/121840/1237780/version/2/file/instruction_S-Adapter_H.pdf But it seems that all the rings and adapters and extenders DON'T work with the Leica S-Adapter H Link to post Share on other sites More sharing options...
ynp Posted March 10, 2016 Author Share #3 Posted March 10, 2016 'Macro Converter' is that the actual name of the 'ring' because I don't see it listed in the manual of the Leica S-Adapter H which can be found here: https://uk.leica-camera.com/content/download/121840/1237780/version/2/file/instruction_S-Adapter_H.pdf But it seems that all the rings and adapters and extenders DON'T work with the Leica S-Adapter H Thank you so much. Yes. It's a ring, I have never heard about this converter before. The description from a photo retailer : The Macro Converter for H Lenses from Hasselblad is designed to improve the close focusing range of Hassleblad H series wide angle lenses. It is specifically compatible with the HC 50-II 50mm f/3.5 lens but will work on all H series lenses except the HCD 35-90mm and the HC 50-110mm zoom lenses. The converter mounts between the camera body and the lens and provides a clear, close-up image. The close range of the lens is similar to that of a 6.5mm extension tube but because the converter has a lens system comprised of 3 elements in 2 groups it will give a clear, noticeably better performance with no light loss. Link to post Share on other sites More sharing options...
jip Posted March 10, 2016 Share #4 Posted March 10, 2016 I don't think it will be compatible. For cheaper macro capabilities I'd suggest go down the Contax 645 lens line. Great Zeiss lenses... Link to post Share on other sites More sharing options...
ynp Posted March 10, 2016 Author Share #5 Posted March 10, 2016 I don't think it will be compatible. For cheaper macro capabilities I'd suggest go down the Contax 645 lens line. Great Zeiss lenses... Thank you. I have some Contax glass already and I use the Contax Makro 120mm and HC120-II for our painting shooting. They are more than adequate for our output. I have swapped my broken Leica 120mm for the Summicron s100mm. I have the Contax 45mm. and 55mm. and want a center shutter medium wide lens. The Leica S45mm. CS lens is expensive, and I am considering the HC 3.5/50-II instead , allegedly it is one of the best wide MF optics. It's offered in a trade-in deal with that macro ring. Hence the question. -- Yevgeny Link to post Share on other sites More sharing options...
jip Posted March 10, 2016 Share #6 Posted March 10, 2016 I see I see! Don't forget that Leica Central Shutter lenses go as fast as 1/1000 the Hasselblad lenses only go 1/800 (on hasselblad bodies) and 1/750 on the Leica S because Leica S cameras work in half stops. I've used the 300mm from Hasselblad H series on the S, works great, including the central shutter (loud though) Link to post Share on other sites More sharing options...
