Leica M - winter landscaping field test
Tobers
Thanks for sharing - I agree with your comments that the Leica M system makes a wonderful landscape photography tool. One of my favorite things about the M system is that hyper-focal focusing actually works, rather than just being a 'guess' with other systems / manual lenses that I've used in the past.
Since almost all of my landscapes are shot at small apertures, I find focusing is extremely quick, easy and reliable. Having the live view / EVF helps immensely when you shoot wide, such as the 21mm SEM that I use.
Just to make this post interesting, I'm including an aurora shot from a month ago. Not a scene most folks think an M240 with a slow lens like the 21 SEM can capture!
All Heineken bottles I think.... :D
See:
  • Replies 46
  • Created
  • Last Reply
Thank you for the reply and for checking my gallery!
I'm not sure that you 'need' a 21. I use a 21mm Elmarit and a 35 'Lux pre for landscapes and I use both equally as much. The 21mm can be more dramatic so it's down to personal choice.
I have no doubt that a 28mm would work very well for landscapes but it comes down to how you use it.
Ernst
PS I've just checked out your tumblr gallery. Great photos!
I enjoyed your review and your photos. Thanks for sharing.
I love using the M system for 35mm landscape photography. It may not give the image quality of a medium format system but still gives spectacular results compared with anything else in full format.  Being lightweight, compact, and portable means it can easily be taken almost anywhere. I like taking a 28 (Summicron or Elmarit), APO-50 and 90 Macro-Elmar. It's also nice taking a lens set that only requires 39mm filters.
Might I add that the 4.0/90 Macro-Elmar is an excellent landscape lens and my preference. One does not need a fast lens for landscape work especially with a tripod, it has spectacular performance from 4.0 down, there is the option of macro if one sees an interesting bit of detail, and it weighs 230 vs 660gm. 430 gm is a significant reduction in kit weight!
Mark
Mark
Yes, hard to beat the 28Elmarit, 50APO and 90Macro-Elmar combo wrt high performance, small size, low weight and the common (small) filter size! Add (or substitute) the excellent 21SEM if a wider focal length is wanted. The latter with 46mm filter, though, but hard to imagine a wide angle lens with 39mm filter thread that is on par with the 21SEM.
I've just returned from a 2-week landscaping trip to Assynt in north west Scotland. My primary weapon was my Leica M-240 with 28 Elmarit, 50 Summicron and 90 Summicron lenses. I've found that people are confused and curious when you turn up to do some landscape photography with a Leica M - it's meant to be a "street" camera isn't it? Definitely not - it's fantastic for landscaping too.
Conditions were simply amazing. Scotland has "interesting" weather in February - basically everything happens several times a day. The result was some unique opportunities which I tried my best to capture.
I benefited from a week's tutoring from David Ward for the first week which was excellent - I highly recommend his workshops. The second week was spent putting the lessons into practice.
For those wondering how my M performed in quite challenging conditions, up against the latest & greatest from Sony and Canon, I've written up my experiences for you to look through. Here are a couple of images as tasters...
It's white again now.
