Leica M9 focussing stuck
Tim Hogendoorn
Good day, dear Leicaphiles.
Since starting in photography about 5 years ago, I quickly learned about the leica cameras and owned quite a few since.
Then finally, 3 months ago I could buy my first digital body; the M9, unfortunately not without any hassle...
Although it is obviously a second hand camera, I got it with one year warranty from the store I got it at.
After a month of using the camera with my 35mm summicron v3, I coupled a 90mm summarit on it and found the focussing screen did not move anymore.
I returned to the store and they took the camera back and sent it for repairs to Camtech (the official camera repair point for Leica in The Netherlands), and after 4 weeks the camera returned with the only repair being done was "realigned focussing".
Now, 3 weeks into using the camera again (with my old 35mm summicron v3) the problem has returned... but only after coupling a 50mm summicron apo on the camera (strange right?)!
This little part shown on the pictures, moves when you focus a lens, as all of you probably know.
Focussing was smooth untill I coupled this 50mm summicron apo on it in a store, and suddenly the problem returned!
The "focussing arm" gets stuck on infinity and feels like it is grinding metal on metal when cautiously moving with a finger.
I own two other M film camera's (M3, M6) and coupling these lenses on the film bodies causes no problems, and i am always very careful with my gems :-)
Long story short (sorry ;) ), has anybody ever have this happening to your Leica camera? Would you guys prefer the camera to be sent for repairs again for a month, or ask for the money back?
And more importantly; what is the official term/name for this camera part in rangefinder camera's?!
Thank you for reading!
Tim,
check that the arm is not bent upward too high and is touching something when moved. It may be that mounting a particular lens with the roller on the very edge of the lens focus rim has bent the roller arm upwards. I had this problem on an m2 a while back and was solved by bending the arm back so that the roller is in the correct position.
At any rate, it is something the store should handle under guaranty. I would not go bending things myself.
Ask the store to send it to Wetzlar. I always bypass Camtech, they are more of a general repair shop than a Leica specialist.
thanks for replies guys, the camera was sent away for repairs again today.
After a call with Leica today, I've learned that it's a pretty common problem.
The problem lies in a mechanical part of the camera (encircled) that moves the focussing arm, beneath the top cover, wich would need to be repolished.
I got the picture from another post on this forum, didn't take it apart myself ;)
thanks.
