wlaidlaw Posted May 28, 2007 Share #1 Â Posted May 28, 2007 Advertisement (gone after registration) Can someone remind me how to stop C1LE opening the processed images as each processes, in another program. I seem to have managed to do this on my iBook and iMac as they don't do it but my PowerMac does. It was opening each TIFF in Photoshop. The set up looks the same on my iBook as it does on my PowerMac. I have bodged my way round this for the time being, by selecting C1LE as the program to open processed images under the attributes tab on processing preferences but it is clear it does not like this. Any help would be welcomed. Â Wilson Link to post Share on other sites More sharing options...
Advertisement Posted May 28, 2007 Posted May 28, 2007 Hi wlaidlaw, Take a look here How to get C1LE not to open images in another program. I'm sure you'll find what you were looking for!
papimuzo Posted May 28, 2007 Share #2 Â Posted May 28, 2007 Hi Wilson, Â under the File menu, you should see Preferences and then you get a sub window where you have the tab Miscellaneous Settings; there you have to uncheck "Automatically open processed images". Done. Hope this helps. Marcel. EDIT: Forgot to say this is with the PC version under Windoze. Link to post Share on other sites More sharing options...
wlaidlaw Posted May 28, 2007 Author Share #3  Posted May 28, 2007 Hi Wilson, under the File menu, you should see Preferences and then you get a sub window where you have the tab Miscellaneous Settings; there you have to uncheck "Automatically open processed images". Done. Hope this helps. Marcel. EDIT: Forgot to say this is with the PC version under Windoze.  Marcel,  Thanks for thought but miscellaneous tab not there on Mac.  Wilson Link to post Share on other sites More sharing options...
carstenw Posted May 28, 2007 Share #4 Â Posted May 28, 2007 Wilson, on the Process Tool tab (gear), there is a checkbox on the left for opening after processing. Is that on? Link to post Share on other sites More sharing options...
wlaidlaw Posted May 28, 2007 Author Share #5 Â Posted May 28, 2007 Wilson, on the Process Tool tab (gear), there is a checkbox on the left for opening after processing. Is that on? Â Thank you Carsten - you have prevented the onset of insanity. As soon as I read your post, I remembered. What a stupid place to put it - it should be in the preferences panel. Â Wilson Link to post Share on other sites More sharing options...
