Variable ND Filter Question
I have a Heliopan 46mm Variable ND that I used on my 46mm lenses when I had them.
Now those lenses are gone I have the Q and before I go and buy a step down ring, I wanted to tap into the wisdom here as to whether the 3mm difference to the Q's 49mm filter size will cause me major vignetting problems.
Any thoughts would be helpful.
x
Its a 46 to 49 step-up adaptor you'll need and my experience of Heliopan is that the filter might be quite thick.
As you are aware, the Summilux lens has a 49mm thread which is quite close in size to the lens surface diameter and I suspect that by putting anything 46mm in diameter in front, will unevenly affect the light across the whole face of the 28mm lens .    Unless you, or someone else tries the combination, we can't be sure.   Why not wait until you can perform a test.  (Unless someone has the combo and can do this for us).
