Leica M240 - shutter stuck, LCD screen won't turn on
atul
Hey folks,
I'm hoping somebody here might have some words of advice.
I'm a 3-year user of Leica M240. Bought it brand new; now using with a Zeiss 35mm/f2 lens. Been working (mostly) well so far (while I was learning RF).
Very recently, while on vacation traveling to UK, my M240 suddenly died. The shutter stuck while composing a frame, and didn't not fire.
 [i live in the US, and had taken 2 batteries + the US charger with me.]
Now, with batteries fully charged, the camera's LCD screen does not turn on. I cannot play any pics already captured, can't see the Menu, Settings, etc.  [Only the bottom right (RED) led turns on when I try to click on the shutter release button, but the shutter does not fully fire/release. :-(( ]
I tried with a spare charged battery, but got the same result. :-((
1. Anybody seen this problem? Is it a shutter problem or something else?
2. Short of sending it for repair (where?) is there anything I can do to diagnose the problem?
Appreciate insights from people who may have seen this problem, or have related experience.
Thanks!!
-AA
Ok, this is an absolutely WAG, but it sounds like you are down to point of trying pretty much anything.
Since you can't see the screen to do a complete reset, let's do it the hard way.  Whenever I power on my M240 the menu always opens to the same place and with any luck yours does also, so let's try to step through it blind.
turn camera off.
insert FRESHLY charged battery
turn camera on
press and release Menu button once
press the top edge of the round navigation control twice
press the right edge of the round navigation control twice
press the press and release Set button once (at this point the camera should reformat the memory card.  I suggest using a known good memory card)
after the camera has formatted the memory card, turn the camera off
turn the camera back on
press the top edge of the round navigation control three times
With any luck, this will perform a complete reset and just might fix something.  All your saved menu settings will be reset to defaults.
I suppose one could actually reload the firmware with this sort of blind procedure if desperate enough.
Also, this assumes that your menu powers up to the same place as mine.
Good luck.
Thanks. Will give it a try when I get home.
Is this some sort of undocumented feature?
turn camera off.
turn camera on
I suppose one could actually reloads the firmware with this sort of blind procedure if desperate enough.
Good luck.
No luck :-((
I tried the Part A of your instructions (formatting the memory card) - but nothing happened.
Specifically -- when I turn the camera ON, the small red LED (bottom right of the screen) flashes on a couple of times and stays on for a wee bit longer than usual (maybe a full second or two?).
Then when I do your instructions (e.g. pressing the Menu button, etc etc) nothing happens; no activity at all on the LED.
I tried it a couple of times. :-/
I'm going to check it again with another freshly charged battery to see what happens.
Any Luck ??
I tried the procedure with another freshly charged battery - but got no response from the camera at all  :-((
I'm sad but more annoyed. Not quite sure what to do here.
Is there anyway to load firmware on this -- but how to do it if the camera does not turn on??
No luck :-((
No luck :-((
Well, if you didn't go all the way through both parts of the procedure you wouldn't expect to see anything on the LCD.  Nothing could have been corrected by running only a part of the procedure, and you would have had to completely finish it to see any difference.  If it worked at all.
