mbarana Posted September 8, 2015 Share #1 Posted September 8, 2015 Advertisement (gone after registration) Hi All, how do you find the distance scale accuracy for hyperfocal focusing? I found mine not very accurate... I took one picture at f/11 manually focused at infinity. Then took others shot at hyperfocal using the distance scale and aligning the infinity mark on f/11, f/8 and f/4 marks. I could get sharp objects at infinity only with the one with infinity positioned on f/4. With f/8 and f/11 objects at infinity were way out of focus. Maybe these distance scales are not considering the high resolution of modern sensors? Thanks everybody for your contribution. Michele Link to post Share on other sites More sharing options...
Advertisement Posted September 8, 2015 Posted September 8, 2015 Hi mbarana, Take a look here Distance Scale/Hyperfocal accuracy . I'm sure you'll find what you were looking for!
pop Posted September 8, 2015 Share #2 Posted September 8, 2015 ...Maybe these distance scales are not considering the high resolution of modern sensors? ... Yes, quite. The depth of field as indicated on your lens applies to a smallish print when viewed from a reasonable distance. Enlarge the image more, and you will see that practically all of the image is slightly blurred. Link to post Share on other sites More sharing options...
jaapv Posted September 8, 2015 Share #3 Posted September 8, 2015 I will once again quote Gunther Osterloh on the subject: "If you want the horizon to be in focus, focus on the horizon". Link to post Share on other sites More sharing options...
