Lens coding - again
george_b
What is the real effect to my images if I set my M8 to "Lens Detection On+UV/IR" when I use a non-coded lens? It is easy to forget to change the settings when out taking photographs. I'm really talking about lenses in the 25 - 90mm ranges rather than wider, My 35, 50 & 90mm date from the mid '70s and think they are wonderful plus they have a sentimantal attachment.
George
x
There should be no effect if you set lens encoding ON or ON+UV/IR and use a non-coded lens. The camera reads its "non-code" as 000000 and translates this into "do nothing." So if you use a mix of coded and non-coded lenses, you should leave the lens recognition on for lenses that can benefit.
scott
