Hasselblad w/560mm Leitz f/6.8 Leitz Wetzlar Telyt-R
pico
Would have to be a 2000F body or similar with focal-plane shutter, since the Leitz 560mm has no shutter of its own.
Also remember that while those "telescopic" two-element f/6.8 long lenses might well "cover" 6x6 - they have severe curvature of field such that only the middle 6mm circle or so is sharp, even on 35mm. Corners get fuzzy really fast.
On the flip side, the glass alone probably would cover 6x6, since it is just two elements (i.e. shallow) - but the rear barrel and/or your modification might cause vignetting. Might need to build a new barrel from scratch (or at least the back half - they separate into two parts in some versions).
http://www.iscanmanuals.com/ebay/opticxchange/01032013pic169.jpg
[... bummer reality information ...]
In a pinch, couldn't I use the 500c rear auxiliary flap/shutter? Oh, it is probably not worth the trouble. I must have been dreaming.
I have a Hasselblad 500mm f:8 which is very good. I had just retrieved it from storage with its dedicated 500c for a shot. It is very heavy, and the Leica came to mind.
The rear flaps would act like a shutter permanently on "bulb" - press the button and they open, release the button and they close. Probably could be used, but only for long exposures.
Consider a 250 Sonnar with 2x Mutar to reduce weight. The Sonnar gets a bad rap as "soft" - but I've discovered it is quite good, so long as you never go below 1/500th second hand-held! The "soft" reputation, I suspect, is mostly from camera shake or slightly-missed focus.
Thanks. With the 500mm I always use a stout tripod, long flexible cable release
and the camera's pre-fire button. That leaves only the leaf shutter. Vibration free.
That's one thing I like very much about the Hasselblad.
