Einst_Stein Posted July 21, 2015 Share #1 Posted July 21, 2015 Advertisement (gone after registration) I have 25mm~135mm covered for my M9, I am looking to extend to 16mm. preferably a single lens to cover 16-35mm more or less. WATE is a choice but it is expensive, and I found I'm more and more lazy to change lens. So a second camera with good 16-35mm range is preferred. ??? Link to post Share on other sites More sharing options...
Advertisement Posted July 21, 2015 Posted July 21, 2015 Hi Einst_Stein, Take a look here 16-35mm for M9. I'm sure you'll find what you were looking for!
johnloumiles Posted July 21, 2015 Share #2 Posted July 21, 2015 I say just get the new 15mm Heliar that is supposed to be amazing. I mean do you really need 16-24? Just seems like a cheaper, more streamlined option then a new system. There's also the 21mm Skopar and Nokton. If you are primarily a architecture/landscape guy then I understand, but if that were the case you probably want to invest in the WATE over all those longer lenses. Link to post Share on other sites More sharing options...
new2leica Posted July 21, 2015 Share #3 Posted July 21, 2015 The only Leica zoom I'm aware of covering your desired range is the 11-23 (x1.5 crop) for the T. You'd give up full-frame of course. Link to post Share on other sites More sharing options...
duckrider Posted July 21, 2015 Share #4 Posted July 21, 2015 Fuji X & Fujinon 10-24 mm meets Your needs in 100%! Thomas Link to post Share on other sites More sharing options...
Einst_Stein Posted July 21, 2015 Author Share #5 Posted July 21, 2015 I say just get the new 15mm Heliar that is supposed to be amazing. I mean do you really need 16-24? Just seems like a cheaper, more streamlined option then a new system. There's also the 21mm Skopar and Nokton. If you are primarily a architecture/landscape guy then I understand, but if that were the case you probably want to invest in the WATE over all those longer lenses. Have you used the 15mm Helliar on M? Link to post Share on other sites More sharing options...
Einst_Stein Posted July 21, 2015 Author Share #6 Posted July 21, 2015 Fuji X & Fujinon 10-24 mm meets Your needs in 100%! Thomas The price of Fuji X +10-24mm seems not much different from T + 11-23mm. How would you compare the image quality and convenience? Link to post Share on other sites More sharing options...
johnloumiles Posted July 21, 2015 Share #7 Posted July 21, 2015 Advertisement (gone after registration) I have not but others swear by it. http://leicarumors.com/2015/05/13/my-muse-the-15mm-voigtlander-super-wide-heliar-iii-lens-review.aspx/ I have shot with the 21 Skopar and it's tack sharp across the entire image. Have you used the 15mm Helliar on M? Link to post Share on other sites More sharing options...
IWC Doppel Posted July 27, 2015 Share #8 Posted July 27, 2015 I have an M9-P which I use 12mm CV II, 15mm CV II, 18mm Leica SEM, 21mm and 24mm Elmarit Leica lenses The only one I am not a fan of is the 15mm CV II due to the magenta casts, I dont like it converted to B&W on the M9 either, but really like it on the MM I will probably pick up a 15mm III and sell the II Link to post Share on other sites More sharing options...
