cirke Posted May 9, 2015 Share #1  Posted May 9, 2015 Advertisement (gone after registration) I have a many 72 and 77mm filters Heliopan or B&W  and I would like to use them on the Noctilux 0.95 and Summilux 24Which adapter ring can I use ?  for the Noctliux any 60 to 72 or 60 to 77 ring ? this one http://www.amazon.com/Fotodiox-Bayonet-60-B60-Hasselblad/dp/B001G445UU ?  what is the  filter size  of the 24 Summilux ??  thank you Link to post Share on other sites More sharing options...
Advertisement Posted May 9, 2015 Posted May 9, 2015 Hi cirke, Take a look here adapter ring for Noctilux and 24 Summilux. I'm sure you'll find what you were looking for!
algrove Posted May 9, 2015 Share #2 Â Posted May 9, 2015 I heard it's a 49mm, but might not be correct. Link to post Share on other sites More sharing options...
rickp13 Posted May 9, 2015 Share #3  Posted May 9, 2015 there is a special filter adapter ring for the 24mm summilux, costing euro 85 at a local hamburg dealer.  LEICA FILTERHALTER E72 für Leica Summilux-M 1,4/24mm ASPH. Nr. 14479  i have only the 77mm versions of my seldom-used filters (IR, polarizing etc) and use various adapter rings with smaller lens diameters.   not so elegant, but works for me.  greetings from hamburg  rick Link to post Share on other sites More sharing options...
darylgo Posted May 10, 2015 Share #4 Â Posted May 10, 2015 Hi Erick, Â The ring you want for the Noctilux is a 60-72mm Step Up or a 60-77mm Step Up. Â The link you posted is a bayonet (B60) 60 and will not fit the Noctilux. Â There are many rings available to fit, most are aluminum, they are thin and weigh very little, occasionally they will bind and be difficult to remove. Â The more expensive rings are brass made by Heliopan. They are thicker, heavier and bind less than aluminum. Â Â http://www.bhphotovideo.com/c/search?Ntt=60-72&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search= Â The 24SX takes Series 7 filters in the hood, the adapter mentioned by rickp13 will allow 72mm filters to fit the lens. Â The adapter has holes so viewfinder blockage is minimal. Link to post Share on other sites More sharing options...
cirke Posted May 10, 2015 Author Share #5  Posted May 10, 2015 Thanks Daryl  Thanks  Rick and Grüß from Würzburg  Then any E ring  , and the best from Heliopan ? Link to post Share on other sites More sharing options...
cirke Posted May 10, 2015 Author Share #6 Â Posted May 10, 2015 Thank you Louis ! Link to post Share on other sites More sharing options...
algrove Posted May 11, 2015 Share #7 Â Posted May 11, 2015 Advertisement (gone after registration) Thank you Louis ! Sorry, I had the 28 Lux on my mind and that was the filter size I was referrring to for you. I just sold my 24 lux and see I still have a never used Leica #14479 filter carrier E72. Link to post Share on other sites More sharing options...
cirke Posted May 11, 2015 Author Share #8 Â Posted May 11, 2015 I shall get the 28 Lus I think :-) Â Will you buy the new MM ? Â Link to post Share on other sites More sharing options...
cirke Posted May 16, 2015 Author Share #9 Â Posted May 16, 2015 Actually I dont find the way to use all my 77mm filters with the Noctilux 0.95 and the Summilux 24mm ? I cannot find 2 rings for that 60->77 and 24summilux?->77if 82mm filters are better no problem I can sell all my 77mm filters and buy 82 but I want to have only one pol filter for all Link to post Share on other sites More sharing options...
darylgo Posted May 16, 2015 Share #10  Posted May 16, 2015 77mm for the Noctilux:  http://www.bhphotovideo.com/c/product/809635-REG/Sensei_sur6077_60_77mm_Step_Up_Ring.html or http://www.bhphotovideo.com/c/product/197567-REG/Heliopan_700644_60_77mm_Step_up_Ring_644.html  77mm for the 24mm/f1.4: Leica adapter - http://www.bhphotovideo.com/c/product/586200-REG/Leica_14_479_E72_Filter_Adapter_f.html plus http://www.bhphotovideo.com/c/product/1026570-REG/sensei_surp_7277_pro_72_77mm_brass_step_up.html   this is the new Sensei Brass Rings, good quality with Knurled Sides.  82mm - you shouldn't have to step up to 82mm, in the Leica world the 21/1,4 would require 82mm along with several Leica S lenses.  Neither the 24/1.4 or Noctilux require 82mm.   The 72mm solution would be my preference, requiring one ring for each lens, while the 77mm solution requires two adapters for the 24/1.4. Link to post Share on other sites More sharing options...
cirke Posted May 16, 2015 Author Share #11  Posted May 16, 2015 Thanks Daryl   Link to post Share on other sites More sharing options...
