yoMammabot Posted May 16, 2007 Share #1 Posted May 16, 2007 Advertisement (gone after registration) The only reason i have not used my 21mm Elmarit on the M8 is the lack of UV/IR filter. My question is this. If I slip a 55e size filter on the 21 mm, can I expect any image cutoff at the edges? Will the M8's crop factor eliminate what would typically show up in non cropped image? thanks for any help! . Link to post Share on other sites More sharing options...
Advertisement Posted May 16, 2007 Posted May 16, 2007 Hi yoMammabot, Take a look here Very wide angles and UV/IR filters. I'm sure you'll find what you were looking for!
chmoss Posted May 17, 2007 Share #2 Posted May 17, 2007 The only reason i have not used my 21mm Elmarit on the M8 is the lack of UV/IR filter.. Try it without the filter - you may like it. Link to post Share on other sites More sharing options...
Artichoke Posted May 17, 2007 Share #3 Posted May 17, 2007 with a BW slim ir/cut on a coded 21 Elmarit & I have seen no problems whatsoever even with a slim polarizer added on top of the ir/cut, I see very little fall off at the edges, but it is just noticeable the 1.33 sensor does have some advantages Link to post Share on other sites More sharing options...
yoMammabot Posted May 17, 2007 Author Share #4 Posted May 17, 2007 Do you guys think that the leica filters are too thick? Link to post Share on other sites More sharing options...
gravastar Posted May 17, 2007 Share #5 Posted May 17, 2007 As an experiment I've stacked two 55mm B+W FPRO filters on a coded 21mm and cannot see any additional vignetting with the lens focused at infinity, open or stopped down. So it looks as if there's a wide safety margin with standard filters when this lens is used on the M8. Bob. Link to post Share on other sites More sharing options...
yoMammabot Posted May 17, 2007 Author Share #6 Posted May 17, 2007 Thank you guys for your input! I feel confident enough to order a filter for the 21mm. Good bye magenta! Link to post Share on other sites More sharing options...
