Hi everyone, new to the forum though have been stalking for some time.
About 2 years ago I started shooting film and developing at home. I'm completely addicted, I find the darkroom and the whole film process so fun.
I'm getting to a point where I want to start experimenting with different filters.
My initial film camera was an M3 with a 50 DR cron and 90 cron (big version), now I'm on an MP with 50 lux asph. (e46) 35 cron asph. (e39) and a 90 cron pre-asph. (e55) It's been a joy to use this new set up, but also frustrating as I don't find myself using the lenses wide open as often as I would like.
Hence my filter consideration.
From research it seems practical to pick up a variable ND filter. Heliopan makes a 55mm filter with which I could use step down rings to fit all my lenses.
However, if I'm going to spend a bunch of money on filters, I want to have all options/combinations covered.
So, considering a polarizer, I'd like to get the Leica swing-out version. (looked at the Lee Filters, but it just seems too much, aesthetically and in application). I know that the Leica polarizer won't work on my 90/2 and will on the 35/2 and 50/1.4, I'm ok with that as the 90mm, for me, is mostly for portraits.
I guess my question is this, if I purchase the Heliopan 55 variable ND and the Universal Polarizer, could I use them together on my 35/2 and 50/1.4? The way I'm figuring this could be done is by putting step-up rings on my lens (35 or 50), screw in the ND filter, then use a step down ring (55 to 46 or 39) to screw in the polarizer. It'll probably look crazy but I'm more curious about whether it'll work.
Perhaps the polarizing filter will be too far away from the viewfinder to accurately adjust the polarizing effect (because of the extra stack)?
Currently, I have UVa filters on all my lenses for protection, so if I keep them on the stack will be even bigger and perhaps cause internal reflections or vignetting?
All advice is appreciated. I haven't bought anything yet, just doing research, so all recommended filter brands, optimal sizes, alternatives, etc. are welcome.
Thanks in advance!
-Alex
[...] my filter consideration.
Stacking variable ND and a Polarizer is not a good idea. Unpredictable outcomes and vignetting are likely.
You might enjoy looking into Singh-Ray's Vari-N-Duo which is a variable ND and polarizer in one unit. It also warms the image slightly.
Thanks for the reply. I'm only finding the Singh-Ray's in 77mm which is pretty big and I would think that it would obstruct the view finder too much for my liking.
The reason I like the Leica one is because it's the only one I've found where you don't need to hold and adjust off lens before mounting with the right polarization adjustment. I'm also not 100% certain that I'll be using ND and Polarization filters together all that much, but it'd be nice to play around with it, just wondering if anyone out there has had personal experience (specifically in terms of stack of filters creating vignetting).
Cheers
Suit yourself.
  • 9 years later...
Hello everyone,
I just acquired a used Leica MP in an excellent condition and shot, for testing, a 18-frame roll with it. I specifically want to mention that, because it was a very bright sunshiny day out there, I mounted a variable ND filter on my 50mm f/2 lens. The other day I received from the lab the results (mailed scans) and was shocked to see that I only received 6 frames and that all of them were extremely dark, to the point where almost nothing was discernible. They look as if they had been very under exposed. Has anyone experienced this? Thank you for your advice.
No - but welcome to the Forum.
I would try again without a filter to check camera.  Presume you are using internal meter? Have you checked it? Does changing ISO give different exposure values?  Even if working, the meter is very basic and you need to ensure you are taking a reading from a midtone and then factor in for highlights and shadows for the results you want.
1 hour ago, niki09 said:
Hello everyone,
What was your meter telling you about the exposure times and were you setting the shutter speed and aperture correctly? Best ditch the ND and try without an impediment next time to cross reference the results, even in bright sunshine you've got a fast enough shutter speed and enough f/stops to get a correct exposure.
Thank you very much for your answers. I too told myself that, because of the dark filter, the film must have been terribly underexposed, but, if I remember correctly, I was metering, before taking the shots, by both turning constantly the front lens of the variable filter and the aperture/speed dial, trying to bring the exposure to the correct values. I also remember that sometimes even turning the front lens of the filter would not change the under/over exposure led arrows in the viewfinder to the round red dot sign. Logically it should be something wrong with the filter. I will definitely try another film roll. Thank you all for your help.
There's no logic in blaming the filter, that will be working as it should, but for normal photography it's not needed and I'm baffled why you are using it. ND filters are used to reduce the amount of light reaching the film or sensor, they aren't a shortcut for routinely or randomly adjusting the exposure, least of all with film which has a very narrow operating range compared with digital. Read the MP camera manual and understand how to set the ISO speed for the film, and then follow the instructions for adjusting the exposure with both the shutter speed dial and aperture ring on the lens.
I thought variable ND filters were essentially two polariser filters mounted together. Varying the angle between them is how the light transmission is altered. Adding a third polariser into the mix is only going to cause problems !
The solution is to use a variable-ND+PL combo filter ( e.g. K&F 2-32 ND + PL ).
You cannot see the degree of polarisation in the viewfinder, as with a flip-out or oversized filter, but you can use the meter to find a dip in light that corresponds to the maximum polarisation. On digital cameras with shutter speed readout the dip is easy to find; on a MP or M6 it is a bit trickier but you can search for the LEDs going from overexposed to underexposed then shift the expose back to where you want it.
