SNPF Posted March 25, 2015 Share #1 Posted March 25, 2015 Advertisement (gone after registration) I've been searching the manual and the internet via DuckDuckGo for a couple of hours now trying to find an answer with no luck. I'm trying to find out if there's an option for either changing or disabling the amount of time a picture is displayed after the shutter is fired? If I'm not describing this clearly let me know. Till then I'm guessing due to no mention anywhere I look that there isn't this capability. Hopefully some on this forum can answer. Thanks in advance. Link to post Share on other sites More sharing options...
Advertisement Posted March 25, 2015 Posted March 25, 2015 Hi SNPF, Take a look here v lux 4 changing display time after a picture is taken. I'm sure you'll find what you were looking for!
stuny Posted March 26, 2015 Share #2 Posted March 26, 2015 In the Custom menu go to Auto Review. Select Duration and then select between hold, 5 seconds, 4, 3, 2, 1 or off. Link to post Share on other sites More sharing options...
stuny Posted March 26, 2015 Share #3 Posted March 26, 2015 Oops! Sorry. That's for the V Lux 114. It's probably similar with the "4." Link to post Share on other sites More sharing options...
SNPF Posted March 27, 2015 Author Share #4 Posted March 27, 2015 Thanks for the suggestion Stuny. It is the same for the V-LuX 4. Did a search of the .pdf instructions using time as the criteria and found the instructions. Thanks again. Link to post Share on other sites More sharing options...
