M240 and Telyt lenses.
Robinyuill
Yes you can but it is not a simple matter of mounting the Telyt OUBIO combination directly on the M240. The OUBIO is a Leica screw to M mount converter and also has a tripod mount which is handy. The Telyts were designed to be used with the Visoflex so you really need a 41mm spacer between the camera lens mount and the OUBIO. Novoflex make a LEM/VIS adapter which does the job. The newer version LEM/VIS II is a set of extension rings that together make up the 41mm spacer. They are quite expensive. You might find something similar on eBay at less cost.
