Leitz Pamoo/Ploot
Does anyone know what markings were on the early Pamoo 90-degree magnifiers that were made to go on Ploot reflex-housings? I believe that the early production of these magnifiers were not marked on their metal surfaces with "E Leitz Wetzlar" or "Leitz" but instead had an inscription around the ocular/eyepiece.
I find no writings on this subject now..........but I recall seeing something on this subject in the past.....????????
I don't find much at all on the subject of the Ploot. I wish that there was a serial number list somewhere.
x
PAMOOs without any writing in front do surely exist... I have some pictures of them in my collection of collectibles "caught on the Net" (my PAMOO, on the contrary has the "E.Leitz Wetzlar" writing.. the "lens styled" one) ; but seems to me that there isn't any engraving around the eyepiece... to be precise, I have also the picture of a PAMOO which hasn't writing on the front, and has the engraving "Ernst Leitz Wetzlar Germany" around the eyepiece... but is a strange item in hammertone finish... and the engraving is in capital letters which makes to think of a later model... maybe part of some sci/tec kit.
Luigi,
I have the same PAMOO as you described. I have no idea where it came from.
I would also like to have a serial number list that tells when PLOOTS and Visos were
made. I can't seem to find a list anywhere.
Ciao, Sully
From LeicaWiki
SN Start SN End Product Year Batch
1000 5213 Visoflex I (w/o alignment feature) 1951 4214
5214 6645 Visoflex I (w/ alignment feature) 1951 1432
6646 7199 Visoflex I (micro versions available) 1952 554
7200 32369+ Visoflex I (single release coupler operation + M-mount) 1952-1962 unknown
TOTAL ASSIGNED SERIAL NUMBERS 1951-1962 31,370+
1001 ~7270 Ploot 1935-1951 ~6270
TOTAL ASSIGNED SERIAL NUMBERS 1935-1951 unknown
Not much! Would like to know more. (Viso 2 & 3 had no serial nos.) -Tim
Luigi,
Ciao, Sully
Just to elaborate on the matter... :
This is my item, very common... the other variant, with "Leitz Wetzlar" ("Leitz" in classic Leica style, "Wetzlar" in capital) I think is later and probably less common
This is the variant with no writing, and classic finishing
This is the "odd one" I quoted... do not remember the source (sometime, somewhere on the Net...) the finishing is clearly different and, even if it is not well visible, there is surely a "modern style" Ernest Leitz Wetzlar Germany writing around the eyepiece. It is the finishing that makes me think of some special apparatus... repro or even something for the lab...
The hammertone model is usually found in USA where they were sold with the latest reproduction focoslide
I would like to present the ancestor of the PAMOO the LKIOO :
Hi JC !! I hoped you'd get into this thread... and supposed you had some untrivial item of this breed :)... LKIOO... it's the model which shows the image laterally reversed, right ? Have you a picture of the eyepiece ? And... why the box specifies that it is for "reprogerat"? Doesn't it fit the PLOOT ?
Hi Luigi, It does not fit as it is a slip-on, not a bayonet mount
I am having a devil of a time attempting to upload photos of the Pamoo that I am wanting to know more about.........so.......I will describe it.
It has a regular "crinkle" finish with no Leitz markings on the front facet (as most Pamoo that I have seen do). It has the same inscription around the ocular lens that the above-pictured "Hammer" finished unit does. Bayonet connection that fits the Ploot that I own (Nr. 6550).
When I attach my 1937 200mm Telyt, images are inverted. Printed pages can be read clearly....but they are upside-down.
Thank you for your replies to my question. I need to give serious contemplation to that which is required to succeed at posting images on this site. Haven't had this problem elsewhere....????
