M2 and 40 cron — framing
RogerW
Having deserted a CL (meter, rangefinder problems) for an M2 I have been a little frustrated by the 50 frame that appears when the great little 40 lens is fitted. Checking the accuracy of the 35 frame, I found it slightly 'generous' but much more useful than the 'miserly' 50 frame,
I considered the filling approach, but this seemed a pity, so I hooked a finger around the lever.
Then it occurred that perhaps something constructed could hold the lever instead. I tried using some thin plywood to cut to shape and after much trial by error, came up with a shape that works for me, held in place by the return spring on the lever. Blackened, it is quite hard to see on the body. It is inserted by a push from the top and removed by lifting the bottom.
To date it has not fallen off!!
x
Clever idea, it saves filing the lens mount to bring up the 35mm frame.
Just a quick thought, you could add a fillet to the basic device that slots behind the frame lever meaning it can't fall off forward away from the camera.
Steve
