24mm f/1.4 ASPH Summilux-M & Frame lines.
Jeffry Abt
I use both of my 24mm lenses without a WA viewfinder, and I find the flow of working through one, focusable eyepiece to be most preferable!
You are going to crop off some image anyways, and you will grow accustomed to estimating what the OVF is not showing you. Unless you are doing precise architectural compositions, and then maybe a tripod and LV is best of all.
But my real answer based on three hopeful, but unfulfilling, test shoots with the 24 SX is does it matter anyway? The outer 10% or so of the image from the 24 SX seemed useless to my taste... if you shoot too tight without a WA viewfinder, will it matter to your composition? I also suspect that focusing for f/1.4 and then moving your eye to frame as a final step will play havoc with your actual focus point.
