Leica M9/Tele Elmar 135 focusing issue.
Moss1310
Hi Everyone- I'm looking for some advice and information. I bought a used Tele Elmar 135 f/4 that looks to be in great condition. However when I put it on my M9, My viewfinder focus doesn't work. When adjusting my distance ring, the lens expands and retracts, but there is no change on the focus screen. I manually selected on my camera menu, but not sure what the problem could be. Any ideas?
Taking the lens from the cam and turning the focus You might see the arm for distance might not move, 'cause the grease is sticky. Give it a try to move the arm front- and backwarts by hand.
Wish success to You
Thomas
http://www.l-camera-forum.com/leica-forum/customer-forum/230896-help-elmar-135mm-f4-not-focusing.html
The messing 'knife' in the lens that leads the lever in the body that steers the rangefinder mirror, is quite recessed in the TeleElmar 135. So they made a sort of extension of this knife to meet and lead that lever, which is unique for this lens. In other lenses the lever has direct contact with the knife. This extension can be taken off with 4 screws. Is this extension still there when you look in the lens from t he back?
Sorry for my English
But if it is missing the lens is basically toast. There are no spares and if you find a donor lens the tolerance will be adjusted to the original lens head, readjusting it to another lens head is a major fiddly operation.
Hi Everyone- Thank you for your kind advice. I am new to rangefinders, so am not very technical. The problem was just as duckrider and otto.f described. The little extender was stuck. I gave it a little push and it popped into place:) and everything seems to be working fine now.
