M39 mount for M8 ?
hiphop
I might have the opportunity to buy a leica lense M39 mount (LTM, Leica thread mount, screw mount). Of course I will need a M39 to M adapter ring in order to use it on my M8.
What are your advice on using an M39 mount with adapter ring for an M8. Any problem known ?
Thanks for your reply and attention
hiphop,
When buying a mount, you should know that there are two designs. One is cut out in the area where the coding should be, and the other fills in that area. You don't want the cut out version as it will make it difficult or impossible to code. I'd ask John Milich about this.
Steve
