HELP (what the hell is this on my sensor)
Guest NEIL-D-WILLIAMS
Well yes, but how does dust from the floor get in a camera held open side up?
By using the vacuum cleaner that has presumably also been used to clean the floor, as Rich suggests ;)
. And a trick is to hold a vacuum cleaner hose as close to the lens opening as possible. That seems to help getting rid of the dust I've loosened.
… And a trick is to hold a vacuum cleaner hose as close to the lens opening as possible. That seems to help getting rid of the dust I've loosened. ...
Beware of static charge that may have built up on the end of the vacuum cleaner hose though.
Pete.
I have dust........I can clean (blow that) but what the hell are these other marks and what do I need to buy/use to get rid of it myself??
Any help will be much appreciated
Oh by the way this is on my Leica M (240)
why do you assume those are not dust? do you think dust only come in perfect dot-shapes?
I've been using a sticky sensor cleaner that Jaap recommended, think it's an Eyelead and have found it to be the best solution. Providing you don't use too much force I can't see it being any more risky in operation than a wet clean.
_______________________
Regards, Tom
Regards, Tom
+ 1
