E-Clypse 34mm 1.45x
mirekti
Is there anyone using this magnifier who could put some comments to it?
I've been using Japan Exposure's 1.35x on the M with 135mm Telyt very successfully (useful on 75mm Cron as well), but at the longer distances (25m and longer) I feel I'd need just a tiny bit more magnification.
Do you thing this 0.1 extra in magnification would be of any help?
Is it possible to remove the eye cup from 1.45x?
Not much.
Can't comment on the optics quality on the eclipse either - which makes a big difference to the crispness of the image and hence ease of focussing ...... so any slight additional magnification benefit might be negated by inferior optics.
The JE 1.35 seems one of the better magnifiers from my trial of a fair selection....... and you do realise there is a half a turn difference in the dioptre correction between 0.7m and infinity ....... and the vertical adjustment of the RF needs to be spot on to work well with your eye centred in the viewfinder......
I have no problems at all with the 1.35x, even using the 135/3.4 .......
