fill flash and Leica mp
I have a Leica mp (film) camera and a Leica SF-20 flash unit. I want to be able to fill flash in certain outdoor circumstances. But, the max sync speed is 1/50 and this is much too slow for the ambient light. What happens if I set the shutter speed faster say at 1/125 or more, and the flash on M mode? Will the light from the flash not come quick enough and therefore will have no effect? An annoying alternative, I suppose, would be to use a dark neutral density filter on the lens and set the flash to M mode with a possible adjustment in the flash power. Or perhaps the A mode?
The Leica has a focal plane shutter and unfortunately the sync is slow. You're stuck at the sync speed or slower otherwise the curtain will block part of the exposure. You'll need to change aperture to match ambient exposure. This is the downside of a slow sync speed with a focal plane shutter (leaf shutters don't have the issue.)
Back in the day with my M4 and PlusX, I would sometimes shoot at 1/125th, being careful to place the subject I wanted filled to the left side of my frame. That way the flash would illuminate the side of the frame that I needed before the second curtain was released.
Or was it the right side... (it was a long time ago...)
Of course, modern cameras will not fire if the shutter speed is set incorrectly with a flash, but the old analogue Leicas were not that sophisticated.
Or slower film. Or a stop and a half or two less manual flash.
You' have to stay at the 50th.
You are tied to the M sync speed of a fiftieth. However, by using ND filters (as has been suggested), slower film and/or smaller apertures you can make fill flash workable. When I did this with my M6 and M7 I used to use it mainly in the autumn/winter and at dusk. Once I could take an ambient meter reading that was around a 50th with an aperture below f8 then I would start to use fill flash, dialling the flash down by a stop and a half on the flashgun. It's a bit hit and miss but you get used to it.
However, fill flash (to put a sparkle into deeply shadowed eyes, say) on a brilliant summer's day at f11 at 250 or 500, it isn't :)
