  • 2 years later...
On 9/21/2014 at 10:31 AM, russell c. greenberg said:
There is an easier way to determine the shutter count on your M8, which I learned on a previous post here.
1) press the right button 4 times.
2) press the left button 3 times.
3) press the right button once more.
4) press info, you will then see a menu in small print.
5) scroll down (hitting bottom button) until you see Body Debug Data.
6) press set and scroll down until you see number of exposures (and the number taken).
It's that easy, too bad that this does not work on an M9.
Thanks so much for this!
Γ—
Γ—
