gbealnz Posted November 6, 2014 Share #21 Posted November 6, 2014 Advertisement (gone after registration) I'm possibly the least qualified to comment, I am not involved in Q/C, I merely fly the areo-stuff on a daily basis. My comment stands though, and I agree with the OP, I don't think this is "Leica at it's best". jaapv has made the point that expansion etc must happen, and I agree with that, and always have, with the longer focal length lenses especially. But if one follows that logic, why does the same Leica lens when fitted to an ordinary M body, not show this effect? The only "variable" if you can call it that is the M-T adaptor. How many of us used to (or still do) slap a lens on, roll it to infinity, and shoot, knowing/assuming that focused at infinity means just that. Now if that said adaptor was made anywhere other than Leica, and freely available on that auction site for a mere $15, then I'd agree, shoddy machining, you get what you pay for. But this is Leica, made by Leica, for Leica. It should be right, and if there was any slight leeway to compensate for that expansion etc, it would/should be so slight it wouldn't be noticeable. Gary Link to post Share on other sites More sharing options...
Advertisement Posted November 6, 2014 Posted November 6, 2014 Hi gbealnz, Take a look here Infinity Calibration with Manual Lenses ..... . I'm sure you'll find what you were looking for!
mjh Posted November 6, 2014 Share #22 Posted November 6, 2014 Now if that said adaptor was made anywhere other than Leica, and freely available on that auction site for a mere $15, then I'd agree, shoddy machining, you get what you pay for. You could get an expensive ‘Made in Germany’ Novoflex adapter and it will still focus past infinity. This is by design. Link to post Share on other sites More sharing options...
Carbon111 Posted November 6, 2014 Share #23 Posted November 6, 2014 The only "variable" if you can call it that is the M-T adaptor. How many of us used to (or still do) slap a lens on, roll it to infinity, and shoot, knowing/assuming that focused at infinity means just that. It's not the only variable. On an M the helicoid containing optical elements is mechanically connected to the rangefinder, so the problem is only seen with long-bodied lenses. On the T you have no (mechanical) focusing connection...as well as three disparate mechanically-coupled metal units, each with their own tolerances. (stacking) Link to post Share on other sites More sharing options...
rijve044 Posted November 16, 2014 Share #24 Posted November 16, 2014 Did somebody read the Instruction booklet of the Leica M adapter T? See A. Focusing/Note: "The distances set on the lens are slightly shorter when using the adapter than when used directly on Leica M cameras. For example, sharp depiction of a distant object is achieved immediately before the mechanical infinity stop on the adjusting dial. This is for technical reasons and is not a fault." So they had an intention!!!!! Link to post Share on other sites More sharing options...
thighslapper Posted November 16, 2014 Author Share #25 Posted November 16, 2014 mmmmm..... I wonder what the technical reasons are ....... presumably to ensure that whatever dodgy lenses you use there is always enough lee-way to allow focussing at infinity ....... Anyway, I prefer to have it self-adjusted so that all my lenses work as I want them ..... Link to post Share on other sites More sharing options...
dkCambridgeshire Posted November 16, 2014 Share #26 Posted November 16, 2014 Sure it's not reasonable to expect any MF lens to focus at infinity when set to infinity … that's both optimistic and dogmatic. Any lens' actual infinity focus position will depend on the ambient temperature thus there is usually some tolerance built in so that the lens focuses past the infinity mark. dunk Link to post Share on other sites More sharing options...
Manolo Laguillo Posted January 28, 2015 Share #27 Posted January 28, 2015 Advertisement (gone after registration) I am using on a daily basis the 28PC Super-Angulon-R on both the M240 and the MM. The maximum detail at infinity is achieved when the fixed white line coincides with the left side of the infinity symbol, that is, when the physical stop has not be reached. Just my 2 cents... Regards from Barcelona. Manolo Link to post Share on other sites More sharing options...
angeche Posted May 2, 2015 Share #28 Posted May 2, 2015 I have just bough a Leica T so still in the infancy regarding use. But I have a lot of Leica R lens (and a couple of Leica Ms) that I have been using with adapters (Panasonic m4/3 and Sony A7R). With tele lens and adapters they usually focus past infinity. You have to be very careful with focusing, and it is a bit frustrating, but in my experience this is how it works!. Anyway better to be past infinity (you still can focus sharply) that short of infinity (you cannot focus at infinity!). Link to post Share on other sites More sharing options...
jankap Posted May 2, 2015 Share #29 Posted May 2, 2015 Does not there exist adapters, that can be adjusted by the user? The leica-built LTM to M adapters are not spot on too? Jan Link to post Share on other sites More sharing options...
bernie.lcf Posted May 2, 2015 Share #30 Posted May 2, 2015 Problem with adapters is: too short and lenses will focus past infinity, which might be annoying but is not a big problem too long and lenses will not reach infinity at all, which is not just annoying but an actual problem spot on and some lenses will either go beyond or not reach infinity because they were manufactured badly or because they are old Bottom line: to be on the safe side for all possible scenarios you would make the adapter just a tiny bit shorter than required. What separates the quality adapters from the rubbish is the ability to shim it in order to reach mechanical perfection - if you absolutely wanted it. I understand that it seems to be en vogue to bash Leica these days, but let us not forget that they are telling people in the manual that the adapter is slightly shorter. This is the best solution for real life (i.e. people who actuallly take pictures with the product) BTW: none of my Novoflex adapters is spot on. I have measured them. BTW2: the LTM adapter is precisely 1mm - not hard to produce Link to post Share on other sites More sharing options...
jcrutcher Posted May 22, 2015 Share #31 Posted May 22, 2015 Interesting issue. Mine focuses beyond infinity also. Another question however. Do you all think the distance scale on a M lens is accurate on the T with adapter? What about the focal range? Since it the T sensor multiplies the focal length 1.5 I'm not sure if these scales are affected. Thank you in advance for your comments. Jim Link to post Share on other sites More sharing options...
