T lenses only APS-C ?
About the new Leica T, we know that Leica may launch a full frame version (when ? 2 years ?) but what about current T lenses, can they cover the full frame or are they only designed for APS-C ?
I don't find any info/test about this...
HI There
I think there is absolutely zero chance of Leica producing a full frame T in the next 2 years, and very little chance that they'll ever do it.
What is certain is that the current lenses wouldn't cover a full frame sensor (especially the zoom)
Jono,
While I have no idea what Leica may or may not do, it is very evident that the mount is designed to accommodate a full frame sensor. There was no need to create the mount size they created if they were only going to use it for APS-C. :) In fact they could have made smaller lenses more in line with the Fuji sizes if the mount had been smaller. It appears to be even larger than the Sony E Mount.
There is. I have explained this a thousand times here (also in LFI, several times in fact) so there probably is no need to repeat it.
Jono,
As Michael had it - there was a reason, added to which, keeping your options open isn't the same thing as intending to do something. . . . and as far as I can see the Fuji lenses are smaller than the T lenses (can't be bothered to check though :) )
all the best
As we get threads like this, it seems there is.:o Maybe a good idea to put it in the T FAQ?
What's the register distance?
It should be the same distance as mounted on the camera. Isn't it.
Anyway, this is academic quest. I am sure the current lens set don't cover FF (why should they). As for whether they could in future or not, who knows.
Thanks to Michael for the FAQ entry describing the large rear element design requirement. I had missed that.
all the best
I had a Fiji for a while. The lenses are NOT smaller - slightly larger I think.
Oops TYPE
all the best
Dammit - I meant AREN'T not are - I quite agree - I think the Fuji lenses are larger and not smaller as well (can't edit my post anymore).
all the best
Jono
I went to a niece's wedding yesterday armed with an M and a T. I will post results to a web site in a day or two. I enjoyed using both tremendously but I used the T quite a bit more. Partly the zoom lens and partly the lighter weight.
Both the M and T malfunctioned once each. The M froze once and the right dial on the T stopped changing aperture. Each time I didn't spend time exploring the problem. On both I removed battery reinserted it straight away and both times it worked.
Did not cause me to miss pictures as it happened but it was irritating.
- Vikas
