jaapv Posted August 30, 2014 Share #21 Â Posted August 30, 2014 Advertisement (gone after registration) To which I may add that the 240 is slightly more sensitive to IR than the M9, to the extent that I feel compelled to convert some shots I took at noon in the tropics to Black and White... The M 8 cuts out 50% of IR, the M9 80% and the 240 at a guess about 70%. To be fair, it is the best we can hope for, gives the need of a thin cover glass for this type of camera. Â But to give the Leica gentleman his due, for the MM it can only harm. Link to post Share on other sites More sharing options...
Advertisement Posted August 30, 2014 Posted August 30, 2014 Hi jaapv, Take a look here What's wrong with UV/IR Filters?. I'm sure you'll find what you were looking for!
erl Posted August 30, 2014 Share #22 Â Posted August 30, 2014 Interesting statistics Jaap. I was not aware of the actual figures. Â Do you know how IR cut filters harm images from the MM? I don't have an MM (yet) but am still curious to know. Link to post Share on other sites More sharing options...
bocaburger Posted September 5, 2014 Share #23 Â Posted September 5, 2014 I still have my IR filters from the M8 days, they are Heliopans and have much better and more scratch-resistent antireflective coatings than the Leica and B+W ones. My main objection to them is the red reflection they show to the public, which I found attracts attention and curiosity. And the M9 and 240 do not have firmware correction for cyan corners with wide angle lenses, which are even more severe with full-frame than the M8. But in my 3 years with the M9 and now an M240 I have yet to encounter any evidence of IR contamination with green foliage or black synthetics. Link to post Share on other sites More sharing options...
erl Posted September 5, 2014 Share #24 Â Posted September 5, 2014 Consider yourself lucky if you have not experienced the IR contamination. Â Since you have the filters anyway, try an experiment with a selection of green foliage at different times of the day. I expect you will see a side by side difference. Likewise, try the black synthetic material test under tungsten lighting. If nothing else, you will learn when to anticipate contamination, if it occurs in front of your lens. Link to post Share on other sites More sharing options...
Jeff S Posted September 6, 2014 Share #25  Posted September 6, 2014 But in my 3 years with the M9 and now an M240 I have yet to encounter any evidence of IR contamination with green foliage or black synthetics.  http://www.l-camera-forum.com/leica-forum/2378393-post82.html  http://www.l-camera-forum.com/leica-forum/2563122-post1.html  Jeff Link to post Share on other sites More sharing options...
Dougg Posted September 6, 2014 Share #26 Â Posted September 6, 2014 ... My main objection to them is the red reflection they show to the public, which I found attracts attention and curiosity. ... With the red "searchlight" effect I am comforted by the thought that the red/pink light represents IR reflected and not hitting the sensor. Â Doug Link to post Share on other sites More sharing options...
erl Posted September 6, 2014 Share #27 Â Posted September 6, 2014 Advertisement (gone after registration) A good way to 'hide' that 'searchlight' is to fit a decent lens hood. It will give better protection from flare and better disguise the IR filter. Link to post Share on other sites More sharing options...
