Help with Visoflex III on M8
Just received the Viso III I bought on eBay. However the mirror retract mechanism won't actuate when in the yellow dot position. Apparently the M8 body is tall enough so that the arm cannot be pushed down far enough to actuate the mirror retraction. I have already adjusted the screw to the highest position. I think I have the correct screw for Viso III, see attached photo. Does anyone have this problem? Is there anyway to adjust the arm or actuation position?
I have checked other threads on this and seems like someone had the opposite problem with the screw being too short....???
Thanks in advance,
Alan
x
Problem solved. There is a little slop depending on whether the yellow dot is set turning the knob clockwise or counterclockwise. One way it works the other way not.
Thanks,
Alan
Since I am always using a tripod with the viso, I completely removed the arm so that I can fit a cable release on the shutter of the camera.
How do you flip up the mirror then?:confused:
