acielpete Posted August 14, 2014 Share #1 Posted August 14, 2014 Advertisement (gone after registration) I have not used live view much, but just using it now,... I don't remember there being vertical lines in the live view screen. two thin white lines near both sides, 1/4 of an inch from each screen edge. and as I switch to this screen from the other live view screens there is a momentary 7.6 at the upper right hand side. the other live view screens do not show these lines, and the lines do not show up in the pictures. that is the horizon screen and the "more information" screen does not have these lines, and when focusing, the lines disappear. the only change is that I just started using the .95 Noctilux, but that seems to work fine. and switching to other lenses, they work fine, but the lines are still there. I have the latest firmware. thanks Link to post Share on other sites More sharing options...
Advertisement Posted August 14, 2014 Posted August 14, 2014 Hi acielpete, Take a look here M240 Live view vertical lines?. I'm sure you'll find what you were looking for!
acielpete Posted August 14, 2014 Author Share #2 Posted August 14, 2014 I just exported my profiles. did reset, and the lines go away. but when I reload my profiles the lines come back again. and that is without using any of my own set profiles, just leaving it at default. Link to post Share on other sites More sharing options...
1234 Posted August 14, 2014 Share #3 Posted August 14, 2014 Sounds like you have called up the display of aspect ratio. Link to post Share on other sites More sharing options...
erudolph Posted August 15, 2014 Share #4 Posted August 15, 2014 If I remember right, since I don't use them, the various aspect ratio indicators are activated by an up or down push of the control wheel? Link to post Share on other sites More sharing options...
acielpete Posted August 15, 2014 Author Share #5 Posted August 15, 2014 If I remember right, since I don't use them, the various aspect ratio indicators are activated by an up or down push of the control wheel? that is it, thanks! Link to post Share on other sites More sharing options...
