benedict297 Posted August 21, 2014 Share #21 Posted August 21, 2014 Advertisement (gone after registration) here are a few images with the marumi ..... first 3 on the XV and last 2 from yesterday with the T+similar zoom ..... Hi, are you shooting these shot on automatic mode? What f number are you getting these at? Just bought one and focus is very shallow, not sure if I am stopping down enough. Thanks Link to post Share on other sites More sharing options...
Advertisement Posted August 21, 2014 Posted August 21, 2014 Hi benedict297, Take a look here Elpro VIb for Leica X Vario ?. I'm sure you'll find what you were looking for!
dkCambridgeshire Posted August 21, 2014 Share #22 Posted August 21, 2014 Hi, are you shooting these shot on automatic mode? What f number are you getting these at? Just bought one and focus is very shallow, not sure if I am stopping down enough. Thanks Depth of field will be shallow(er) with any camera when focusing close. You should consider experimenting with aperture priority and take sets of images of the same subject at e.g. ISO 200 and ISO 400 … using every available aperture setting - with the camera on a tripod and letting the camera select the appropriate shutter speed. Then compare the results and decide which suit your needs/style. dunk Link to post Share on other sites More sharing options...
dkCambridgeshire Posted September 6, 2014 Share #23 Posted September 6, 2014 A well known UK d..d..dealer is currently listing three Leitz Macrotar VIb achromatic close-up lenses for just £15 each which are identical to the Leitz Elpro VIb … both are 4.92 diopter. These are bargains considering they are genuine Leitz achromats and with a bit of ingenuity their Series VI (44mm) threads can easily be adapted to fit both the 43mm XV filter thread and the Kiwi 49mm filter adaptor available for the X1 and X2. Just glue a suitable stepping ring onto the Series VI male thread e.g. use a 46mm interior to 43mm exterior step ring for the XV … apply tiny amounts of epoxy to the front of the step ring and the rear of the Macrotar where their surfaces touch … no need to apply the epoxy to the actual threads … thus possible to make a superb achromatic c/u lens at minimal cost … and stacking two Macrotars will result in a very high quality 9.84 diopter c/u lens. dunk Link to post Share on other sites More sharing options...
dkCambridgeshire Posted September 6, 2014 Share #24 Posted September 6, 2014 A well known UK d..d..dealer is currently listing three Leitz Macrotar VIb achromatic close-up lenses for just £15 each which are identical to the Leitz Elpro VIb … both are 4.92 diopter. These are bargains considering they are genuine Leitz achromats and with a bit of ingenuity their Series VI (44mm) threads can easily be adapted to fit both the 43mm XV filter thread and the Kiwi 49mm filter adaptor available for the X1 and X2. Just glue a suitable stepping ring onto the Series VI male thread e.g. use a 46mm interior to 43mm exterior step ring for the XV … apply tiny amounts of epoxy to the front of the step ring and the rear of the Macrotar where their surfaces touch … no need to apply the epoxy to the actual threads … thus possible to make a superb achromatic c/u lens at minimal cost … and stacking two Macrotars will result in a very high quality 9.84 diopter c/u lens. dunk Illustrating the 4.92 diopter Leitz Macrotar VIb attached to X Vario via custom made SRB Griturn Series VI to 43mm stepping ring. Leitz achromatic Macrotar lenses date from the mid 1960s; they are coated and are just as good as any modern achromatic c/u lens. This custom stepping ring cost approx. £30 but the home-made version described above would cost less than £5. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Best wishes dunk Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Best wishes dunk ' data-webShareUrl='https://www.l-camera-forum.com/topic/231343-elpro-vib-for-leica-x-vario/?do=findComment&comment=2664951'>More sharing options...
