GPS not working
dennyg
I'm rather new to Leica equipment, so I may have missed something obvious. I recently purchased a new M-240 and the Multifunction grip. Problem is that the GPS does not seem to be working. It is turned on in the camera menu, I had it outside for around an hour today so it had a clear sky view but the "X" never left the GPS symbol and the photos show no location in Lightroom.
Any ideas on what the problem may be?
If you were in the canyons of downtown it may have had an effect. The GPS receiver is in the top of the grip. Maybe try in an open area. Navy Pier would be a good choice. Also make sure the knob that attached it is snug and the baseplate seated against the body.
Well, I'm not really in Chicago, just the far burbs. And, yes, there is a Chinatown but I've never been there.
Where I am, there is wide open space, nothing to disrupt the GPS signal. My iPhone gets good GPS even in my basement. But I was outside with the M and never got a lock indication. In fact, I have never seen a signal lock since I installed it. The cover is seated and tight, etc.
Are there any other switches or controls besides the ON/OFF in the camera menu?
Not that I know of. I would remove and reattach the grip. Turn the camera back on and give it a go while walking around for a while. Short of that it may not be working and you may have to exchange it.
What firmware are you using? There was a bug, that if the GPS was disabled for location reasons, it could take 24 hours to re-sync. That was reduced to 5 minutes in the current FW.
But considering your location, I would test the HG as Exodies suggests.
I'm using the latest firmware (15, I believe). Unfortunately, my only other Leica is an X-Vario, so I can't try it on another body.
I guess I'll need to contact Leica and see what they advise.
  • 3 weeks later...
As of this morning, I've tried everything and still no GPS.
Then I got the bright idea to use the reset. After resetting the camera and re-entering my preferences, the GPS is now working well.
Thought I'd post this in case anyone else is experiencing the same problem.:)
I'm curious about this feature so excuse my ignorance , what does gps do?
Does it auto show location in Lr
I have been uploading to flicker and tagging location, not sure I know what advantages grip but was wondering
Yes it does. It tags the photo with geographic location and shows location on a map in lightroom.
Thanks did not know that was thinking getting the grip for extra hold and this feature
Thx for info
One other feature is you can use the USB cable to download the images rather than unfastening everything to get at the card.
