jip Posted January 28, 2014 Share #1 Posted January 28, 2014 Advertisement (gone after registration) How to determine if a lens will work on the Leicaflex SL? Link to post Share on other sites More sharing options...
Advertisement Posted January 28, 2014 Posted January 28, 2014 Hi jip, Take a look here Leicaflex SL compatibility . I'm sure you'll find what you were looking for!
leicaphilia Posted January 29, 2014 Share #2 Posted January 29, 2014 2 or 3 cam lenses will work fine on the SL. 1 cam will work but only with stop down metering. The 24mm 2.8 will not work on the SL but will work on the SL2 due to the depth of its rear element. Link to post Share on other sites More sharing options...
wildlightphoto Posted January 29, 2014 Share #3 Posted January 29, 2014 2 or 3 cam lenses will work fine on the SL. 1 cam will work but only with stop down metering. The 24mm 2.8 will not work on the SL but will work on the SL2 due to the depth of its rear element. MOST 2- or 3-cam lenses will work fine on the SL. The ones that will not include the 24mm f/2.8 Elmairt-R, 16mm f/2.8 Fisheye, late model 19mm Elmarit-R, either 15mm lens, 35mm f/1.4 Summilux-R, and the early 80-200mm f/4.5 Vario. There are other newer lenses that may have been converted from 3rd-cam or ROM to 3-cam (for the SL2) but will not work on the SL: 90mm APO-Summicron-R, 35-70 f/4, 21-35 Vario, last 50mm f/1.4 Summilux-R (E60), probably the 28-90 Vario. The 1.4x APO-Extender-R can be modified to fit the SL (with stop-down metering) but the 2x APO-Extender-R cannot. Link to post Share on other sites More sharing options...
TomB_tx Posted January 29, 2014 Share #4 Posted January 29, 2014 The R-series (later) lenses that won't work on the SL have a modified bayonet (wider lug) so they won't fit onto an SL, thus no worry about damage. That helps if you already have the lens, but if you are shopping it isn't much help. I had my old 2-cam 135 modified to 3-cam by one of the respected US aftermarket techs, and it took a year "waiting for parts." It came back fine, but with the bayonet mount replaced with one from one of the non-SL lenses. It fit a R-series body fine, but I had to compare mounts and grind a bit to use it again on my SL, where it originated. It still feels most natural on the SL. Link to post Share on other sites More sharing options...
wildlightphoto Posted January 30, 2014 Share #5 Posted January 30, 2014 I had my old 2-cam 135 modified to 3-cam by one of the respected US aftermarket techs, and it took a year "waiting for parts." Waiting for parts?!? An old 3-cam 14198 macro-adapter-R can be canibalized for the cam, shims and screws and the remaining pieces are existing parts slightly modified. Putting an R-only bayonet mount on it was clearly an error, there's no reason the tech should have done that; the original should have been fine. Link to post Share on other sites More sharing options...
TomB_tx Posted January 30, 2014 Share #6 Posted January 30, 2014 Waiting for parts?!? An old 3-cam 14198 macro-adapter-R can be canibalized for the cam, shims and screws and the remaining pieces are existing parts slightly modified. Putting an R-only bayonet mount on it was clearly an error, there's no reason the tech should have done that; the original should have been fine. I agree, which is one reason I haven't used this tech again. Link to post Share on other sites More sharing options...
jip Posted January 31, 2014 Author Share #7 Posted January 31, 2014 Advertisement (gone after registration) Thanks for the replies guys! Link to post Share on other sites More sharing options...
jip Posted January 31, 2014 Author Share #8 Posted January 31, 2014 leicaphilia Nice website/blog! Link to post Share on other sites More sharing options...
