jaapv Posted December 25, 2013 Share #1 Posted December 25, 2013 Advertisement (gone after registration) Has anybody figured out a way to use Bridge CC with a twin screen setup? Adobe removed the New Synchronized Window command!!:mad: Link to post Share on other sites More sharing options...
Advertisement Posted December 25, 2013 Posted December 25, 2013 Hi jaapv, Take a look here Bridge CC mutilated.. I'm sure you'll find what you were looking for!
sanyasi Posted December 26, 2013 Share #2 Posted December 26, 2013 I am not sure exactly what you are asking. I am able to use Bridge and I use two screens: Bridge on one and Photoshop on the other. I suspect that you are trying to use Bridge across two screens or have different parts of it on different screens. If that is the case, I suspect that the problem stems from a change made in the Apple OS. Now when you open an app on the second screen, its menu appears at the top of that screen rather than at the top of primary screen. But I am just guessing given the limited description of the issue. Best of luck Link to post Share on other sites More sharing options...
pop Posted December 26, 2013 Share #3 Posted December 26, 2013 I don't know the products involved, but the problem outlined in this thread seems a bit similar to me. Link to post Share on other sites More sharing options...
jaapv Posted December 26, 2013 Author Share #4 Posted December 26, 2013 I found the problem on the Adobe forums as well. As they removed the synchronized window command in Bridge CC, it is impossible to have the preview in Bridge on a second screen. It should be possible to expand the single screen, but then you run into scrolling problems. I was hoping somebody would know a trick. Photoshop and OS have nothing to do with it, I fear . The only solution now is to use LR as a file browser and export to PS. Or use Bridge in a single window. Link to post Share on other sites More sharing options...
