cbretteville Posted April 17, 2007 Share #1  Posted April 17, 2007 Advertisement (gone after registration) Went to a store that sells bathroom fittings and plumbing materials yesterday and asked for an o-ring with the inch dimensions first posted by Al Tanabe. As we're metric over here, that dimension isn't readily available.  But: They had a kit they use to create custom o-rings so here is what we did and what works for me:  * The tube used was a ø1.6mm (circular) * Cut a length of 120mm and * Glue the ends with the appropriate Locktite (part of the kit) crazy glue.  The circumference of the e39 filter is slightly larger than 120mm, but this ensures that the o-ring stays in place. The 1.6mm tube makes for a tight, but not impossible fit. A 1.5mm tube might be better.  One thing to be aware of. Depending on how perfect the joint of the ring is you'll want that at a part of the filter that isn't being covered by the tulip hood on the CV15.  Cheers, - Carl Link to post Share on other sites More sharing options...
Advertisement Posted April 17, 2007 Posted April 17, 2007 Hi cbretteville, Take a look here CV15 w/UV/IR filter: A metric O-ring. I'm sure you'll find what you were looking for!
steich Posted April 18, 2007 Share #2  Posted April 18, 2007 Hey Carl, I calculated Al´s non-metric O-ring dimensions to the metric system. It´s 33,05 mm (inner diameter) and 1,78mm "thick". It is stretched when put over the filter´s thread, so it fits tight, but it fits- and works fine with my CV15! Stefan Link to post Share on other sites More sharing options...
willy Posted May 2, 2007 Share #3 Â Posted May 2, 2007 I took 35x 1,5. That's OK Link to post Share on other sites More sharing options...
Photoskeptic Posted May 3, 2007 Share #4 Â Posted May 3, 2007 Gee guys, thanks. I still have a metric o-ring kit left over from my Italian car days which should do fine if I ever get my filters from Leica:rolleyes: Link to post Share on other sites More sharing options...
como Posted June 1, 2007 Share #5 Â Posted June 1, 2007 I used a piece of an old bicycle tube. Cut a ring out, stretched it around the E39 filter and cut off the material outside the filter. It fits in very tight. Maybe a cheap and fast solution. Link to post Share on other sites More sharing options...
