Guest NEIL-D-WILLIAMS Posted September 19, 2013 Share #1 Posted September 19, 2013 Advertisement (gone after registration) Guys, I noticed that the frame lines on my new M sometimes dim down rather than staying very bright...................is it a battery saving function or something else? Link to post Share on other sites More sharing options...
Advertisement Posted September 19, 2013 Posted September 19, 2013 Hi Guest NEIL-D-WILLIAMS, Take a look here Frame lines fluctuating between bright and dim. I'm sure you'll find what you were looking for!
pico Posted September 19, 2013 Share #2 Posted September 19, 2013 Guys,I noticed that the frame lines on my new M sometimes dim down rather than staying very bright...................is it a battery saving function or something else? The camera is designed to dim the frame lines when the ambient light dims. It is to help your view and focusing. It is great also that they gave a choice of red lines. FWIW, that's the way earlier Leica rangefinders have worked because the frame lines are illuminated by ambient light. Link to post Share on other sites More sharing options...
Paulus Posted September 19, 2013 Share #3 Posted September 19, 2013 Guys,I noticed that the frame lines on my new M sometimes dim down rather than staying very bright...................is it a battery saving function or something else? When you point your Leica M camera toward a light source which is very bright, the frame lines light up.Point the to a darker source they diminish. Logic to me, because in very light areas you should see the frame lines with less contrast. I made an experiment with the frame lines of my MP next to the M. You still can see the frame lines of the MP very well in the same circumstances. Only difference is, that the frame lines of the M appear to be brighter and thicker than the MP lines. You can see the moment you compare the two how fragile the MP lines look. But fragile can also be quite nice... The lines of the Leica M work fine, they only are a little bit bulkier. Just as the camera in comparison with the MP... Link to post Share on other sites More sharing options...
jaapv Posted September 19, 2013 Share #4 Posted September 19, 2013 But the 50/75 lines are a lot more usable on the M. Link to post Share on other sites More sharing options...
Paulus Posted September 20, 2013 Share #5 Posted September 20, 2013 But the 50/75 lines are a lot more usable on the M. Yes I like the 50mm lines too! Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted September 20, 2013 Share #6 Posted September 20, 2013 But the 50/75 lines are a lot more usable on the M.Agree I really like the 50 frame lines:D Link to post Share on other sites More sharing options...
